WILL AN AFTERMARKET WIPER BLADE FIT? - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 10-30-2010, 07:06 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat Big-Red-Lariat is offline
Big-Red-Lariat is starting off with a positive reputation.
Trying to install a 20 inch ANCO winter blade on my 2008 ESCAPE but the arm doesn't have the standard 90 degree bend like an F150.
Is there a trick to installing these? None of the plastics adaptors seem to match up to the ESCAPE wiper arm. Original summer blade has two little push tabs on either side to temove it so...does this mean I need a proprietary FORD winter blade?
Old 10-31-2010, 08:57 AM
Rancha9's Avatar
Rancha9 Rancha9 is offline
Rancha9 is starting off with a positive reputation.
What year? I don't know if they made different blade arms for different years, but it's a pain to find good blades for my '08. Currently running Rain-X Lattitudes....
Old 10-31-2010, 03:05 PM
2008 ESCAPE XLT. Two aftermarket parts places were unable to sell me blades to fit the oddball shaped wiper arms.
Has anyone put aftermarket winter blades on a 2008 Escape and what brand comes with an adaptor that will fit the arm?
Old 10-31-2010, 04:30 PM
Rancha9's Avatar
Sorry... I completely read past the year in your first post... Too much yardwork today... The only good monobeam wiper I found that fits this thing is the Latitude, at least from what's available down here... We don't get winter blades, so I can't help you there. I guess if Rain-X makes a winter blade, they might work...
Old 11-01-2010, 10:31 AM
gasman6674's Avatar
gasman6674 gasman6674 is offline
gasman6674 is gaining momentum as a positive member of FTE.
I found mono beam blades at Menards to fit wife's 09. I would try another parts store
Old 11-11-2010, 04:20 PM
turns out that the dealer carries an all rubber-surrounded blade with the special ESCAPE arm fitting, 4 times the price of the ANCOs I usually buy at WALMART for my F150S...so I bought em reluctantly.
Has anybody found anY aftermarket blades that fit the ESCAPE?
Old 11-11-2010, 05:13 PM
tonyford tonyford is offline
tonyford is starting off with a positive reputation.
I don't play around with wiper blaces, always use Trico..
Trico Wiper blades for 2008 Ford Escape
Product Type Description Part Number:
NeoForm Blade - Driver & Passenger Side Trico#: 16-2013
Winter Blade Blade - Driver & Passenger Side Trico#: 37-2013
Exact Fit Blade - Rear Trico#: 12-E
Amazon sells the winter blade for $12.29 each..
Here:
http://www.amazon.com/gp/product/B00...NJMR13QJ3Y2EX1
Old 11-12-2010, 02:25 PM
YoGeorge YoGeorge is offline
YoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to behold
Goodyear Assurance blades are beam types and there is a listing for 08-09 Escapes. They are $8 each at Costco. Last month, they were buy one, get one free--$4 each (I bought the limit of 2 pairs). They have been lasting me a LONG time. There are a ton of adapters in each package, more than I've ever seen with any other blade. Goodyear Wiper Blades Applications - for FORD If the beam blades will work for you (they do for me, in Michigan winters), the Goodyear Assurance deal from Costco cannot be beat. George
Old 12-29-2010, 09:01 AM
2010escape 2010escape is offline
2010escape is starting off with a positive reputation.
After our recent snowstorm here in the northeast and dealing with frozen wiper blades. I went to Walmart and bought 2 Anco winter blades, after spending more then a few minutes trying to remove the blades from the Escape. I finally figured out that the tabs and the rounded end are all part of the blade and are removed as one piece after squezing the tabs [new fangled stuff]. But there was not any adapter in the pkg. to fit the arms. Back to Walmart to return them. My store didn't have too many 20 in. blades.
I went to Autozone and bought 2 Rain X Latitude blades, supposedly good for rain, sleet and snow, time will tell. They look good, and they did have the correct adapter to fit the Escape arm, I read the instructions a couple of times to figure out how to change from the adapter on the blade to the Escape adapter.
The 2nd one took 2 minutes after spending considerable time [much more then 2 minutes] on the 1st one.
Happy Holidays, Ed
AFTERMARKET WIPER BLADES? Big-Red-Lariat 2015+ F150 4 01-21-2017 06:03 PM
Wiper Blade Refills MikeB 88 General Automotive Discussion 4 02-19-2016 07:24 AM
Wiper Blade Replacement on a 2013 Explorer Choptopjimmy 2011 & Newer Explorer 2 01-03-2014 06:30 PM
WILL F150 WIPER BLADES FIT A 2008 ESCAPE? Big-Red-Lariat 2004 - 2008 F150 7 11-01-2010 06:30 PM
How to remove rubber wiper blade arm assembly? razor_jim Aerostar 5 01-11-2004 01:23 PM
Tags
2008, 2009, anco, blade, blades, cover, escape, f150, ford, hybrid, installing, match, red, winter, wiper, wipers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
