You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Used clear headlights and corner lights from Ebay seller parasitesingle. I recommend using the stock adjusters because the ones that come with it aren't very good quality. Lights fit very well.
I'm planning on getting clear LED's for the corner lights but will get around to that later. I'm using Sylvania Xtra Vission bulbs and I'll get night shots later...
Old Lights:
New Lights:
Compare old vs new:
Remove grill/corner/turn/surround pieces:
Remove header panel, two bolts on each end, one at inside bottom corner of headlight, two each side at ends of grill hole, one bottom center (8mm, 11 total)
What it should look like: (corner/bumper attaches here)
What one side looked like:
Fixed the cracked pieces with JB Weld and sheet metal
3 Headlight clips hold it in, remove and then re-install on new lights
Finished!
Much better!
__________________ Brownie (Evan)Ooh-Rah! Once a Marine Always a MarineOregon Chapter Member '95 F350 CC 4x4 - 7.3 PSD, 190k, Built E4OD, SRW Conv, 4x4 Conv, Rosewood Stage I's, PHP Chip, 6637 Intake, 3" DP, Lost Kitty, 4" Exhaust, 3" RSK, 38 gal rear tank, fuel vent mod, 140v IDM, HPX, FPR Shim, 3.55 gears '10 Escape, 200hp 3.0 V6, 4x4 - Stock
1962 Ford F100 flat bed 4x4, 223, 4spd.
1962 Ford F100 Unibody with Olds 330 & Jetaway
1944 Ford GPW (Jeep) with 1947-48 Willys L-134
To join the Oregon Chapter, click HERE
__________________
Jim- Slackmaster #22, I'll get to it someday BS'er #6. 1996 F250 CC Shorty 4X4 E4OD 7.3L Diesel
Mods: 6637 air filter,203 F t-stat from Diesel Site-finally heat! HPX line, Tymar 3-4 dp to 4" exhaust, E4OD "The Cure" 30K mod for now, 140IDM mod, ISSPRO ev1 egt, trans temp, boost, adrenaline HPOP med-oil, superduty rear springs, 91 D60, 01 excursion 7.3 4x4
Looks way cool! Man that truck just keeps looking better and better... nice work
__________________
Ed - Lincoln City, Oregon - Oregon Chapter Member | Join Our Chapter Here
Machinist/Programmer - Jim Meyer Racing Products 1992 F250 S-Cab 4wd 7.3L IDI ZF5 - Straight Pipe, Ram Air, IP Turned Up, Bi-Xenon 6k HID Lights in Clear Euro Lenses.
1975 F250 Camper Special - Soon To Be Transformed!
Looks great!..........way better than the cloudy old stockers.
__________________
93 F-250HD SC 460 E4OD
96 Explorer Limited 4.0 V-6 OHV
93 Ranger Splash 2.3 5spd only 51,000 miles!
84 Ranger 4x4 2.8 V-6 5spd......450,000 miles, now on a brand new 2.8
Dave
Oregon Assistant Chapter leader: To join the Oregon Chapter, click HERE
__________________
Mine came with them, but from what I hear they aren't hard to install. You can buy the whole kit for $40 from LMC Truck. and the power wire for them runs behind the passenger side kick panel on all the trucks whether they came with the lights or not.
I love them. Makes it look more like a truck. I need some new lenses for them though, they're getting old and cracked.
Excellent conversion of the headlight. What is your opinion of the quality of the replacement lens's you bought on ebay? Was the company easy to deal with? How long did it take to change out?
Thanks
The seller on Ebay was pretty easy to deal with. They shipped out 2 days after my payment went through and were here within a week. THe shipping cost was a lot, but total price including shipping was reasonable.
The quality of the lenses seem very good. The adjusters aren't as good as the stock pieces but you can re-use the stock parts on the new ones.
It would have gone faster if I didn't have to repair those two holes so I'd say probably 2.5 or 3 hours from start to finish if you didn't have to fix anything.
Thanks for the quick reply. I've never purchased anything on ebay. I've seen the replacement lenses through some online parts suppliers, but they want over $100. plus shipping for a set. Sure gives your truck a sweet new look.
I agree. They make your truck look way newer. Great Job. I like them. I did the same thing with the ebay replacements. Love them:
Do I have to say before/after? Ha, It kind of speaks for itself
__________________ Bryce - Big BS'er #7 The Green Machine Not So Early 99' 7.3L F-250 PSD_471hp / 1024 tq ! Mods:35-12.5-18 Cooper Muds_Moto Metal 18"s_3" 4" Lift_4" Turbo Back Exhaust_Turbonetics_Rosewood Stage II SS 160/100s_Terminator T500_6637 AIS_JWVB_HPX_NVK4 PCM_Cales Tunes_Autometer Cobalt Gauges
