scan gauge II
10-30-2010, 04:29 PM
on
scan gauge II
just got my scan gauge got it to read EOT but can't figure fow to get ECT or boost any ideas what i am doing wrong thanks
10-30-2010, 04:37 PM
ect is listed as mwt and needs to be re-labeled if my notes are corrct?
10-30-2010, 04:46 PM
mine is fwt for ECT. Didn't need to program it. It is already there.
My boost acts up, not sure why.
10-30-2010, 04:59 PM
Quote:
Originally Posted by
amdriven2liv
You are correct. If gjnicholas does need to program it I do have these parameters:
TXD= 20
RXF = 8
RXD = ---
MTH = ---
Name = MWT
Degrees F
10-30-2010, 05:12 PM
on
will check that out thanks
10-30-2010, 05:22 PM
on
found fwt works good thanks any one know what boost is
10-30-2010, 05:30 PM
There was a link that someone had the boost codes. And the last part of the code was for the elevation where you live for "pressure". I'm not sure, but try a search for Scangauge and boost, you might stumble on it. I think mine might be set at wrong pressure.
10-30-2010, 05:37 PM
10-30-2010, 05:42 PM
on
thanks got it will try soon when i get chance
10-30-2010, 06:09 PM
Is the "boost" xgauge just the MAP xgauge with some math applied to it to remove the baro pressure?
10-30-2010, 06:18 PM
moebdick
I believe that is a true statement. But what do I know, I stayed at a Motel 6 last night!
pickle40
01-10-2015 08:50 PM
arkredneck
11-28-2011 11:45 AM
Randy777
09-06-2011 03:38 PM
tshrager
05-04-2011 08:09 PM
Farmboypowerstroke
03-11-2010 05:13 AM
