frontend in 86 in f250 - Ford Truck Enthusiasts Forums
Old 02-25-2003, 09:17 PM
etson etson is offline
etson is starting off with a positive reputation.
Question frontend in 86 in f250
I have an 86 F250 4x4 with a 351W and C6 tranny. Its a twin I Beam. I was wondering what type of frontend it is. I believe its a Dana 44 with reverse cut ring and pinion but im not sure. The number on the axle housing is: P 345 1
41582 303
and the tag on the front end says: 345 E6TA JB
610264 2
Thanks
Old 02-26-2003, 02:04 AM
cjcathey2002 cjcathey2002 is offline
cjcathey2002 is starting off with a positive reputation.
it could be a twin traction beam, looks like you have 3.45:1 gears. i am not too knowledgeable in 4x4s i have a 4x2. good luck.
Old 02-26-2003, 07:06 PM
bremen242's Avatar
bremen242 bremen242 is offline
bremen242 is gaining momentum as a positive member of FTE.bremen242 is gaining momentum as a positive member of FTE.
I am not 100% on codes on the Dana front; however, a couple easy pointers:
if your u-joints on your front axle have C-shaped clips on the inside of the axle, its a dana 44TTB.
if the u-joints have snap rings on the outside (like your driveshaft), its a dana 50TTB
also, if you're GWVR is 8600 or under, you have a Dana 44TTB, if its over 8600 (like 8750), you have a Dana 50TTB.
I've only seen Dana 50s under extended cab F-250s. (for the extra weight i assume). if you have a snow plowing package, you might have one as well.
as for gear ratios, on your door tag, if your axle code says "33", it should be 3.54, 35 i believe is 4.11.
also, afaik, all 4x4 front ends on f-series are reverse rotation high-pinion, which takes a different ring gear than say a chevy or jeep dana 44.
1978 f250 4wd conversion idea Ashton460 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-15-2014 09:59 AM
New guy, front end conversions Samsn4 1948 - 1956 F1, F100 & Larger F-Series Trucks 31 02-27-2012 07:06 PM
34.5" Will it fit? 86f250XLT-4x4 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 08-09-2011 10:40 AM
2008 F350 - Salvage Title - Would You Buy It? Furian 1999 to 2016 Super Duty 17 03-05-2010 03:30 AM
86 f250 frontend etson Clutch, Transmission, Differential, Axle & Transfer Case 1 02-26-2003 05:48 PM
Tags
303, 41582, 6102642, 86, axle, code, diesel, e6ta, end, f150, f250, front, frontend, gear, ring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
