1966 Galaxie 390 4V tune-up
Bought a 1966 Galaxie Ltd with Thunderbird 390 4V engine today. Have not purchased any service/workshop manual yet and would appreciate tune-up information (I know that I am in the truck forum, but maybe you can help anyway:
- ignition timing (w or w/o vacuum line attached)
- dwell angle
- spark plug and gap
- idle speed
- idle mixture adjustment
The engine has OK compression (between 170 and 190 psi), but runs rough at idle and surges at higher speeds.
Thx /ekkehard
- dwell angle
- idle speed
Thx /ekkehard
- dwell angle
- idle speed
Thx /ekkehard
- dwell angle
- idle speed
Thx /ekkehard
Dwell is 28° to 34°
Champion number RF9YC @.035"
600 RPM
Starting point is 1 1/2 turns out from lightly closed, then adjust for highest RPM
Bear is correct with the spec's on your engine.
In MHO, However, stay away from those junk *** champion spark plugs. They may be good for 2 cycle boat motor's, but that's about it. I've pulled more defective Champion spark plug's out of motor's than all other brand's combined, most when they were brand new. It didnt matter if they were used in a 25KV or 50KV ignition system. That is not a boast, but a fact from a EX master NIASE\ASE pro that worked in the field for a day or two. As soon as the anylizer was hooked up on a new tune up that had a secondary spark\voltage issue, and the spark tail from the spark plug was grounded\missing, guess Champion as the plug and you would win money in a bet. Their quality has not gotten better since I have changed job descriptions.
With that being said, you cannot go wrong with Autolight spark plug's for the FE engine.
Also why would a plug work in 2 strokes and not in 4 strokes when 4 strokes are 5 times easier on plugs than 2 strokes are?
The 2 cycle info was a joke just for you, from a previous post of your's justifying these junk *** plugs in boat motor's. Jeesh Bear, I cant even throw you a bone without you snarling.
If you want to go a little above stock, for 50 KV secondary spark for example, there are lot's of options as there are oppinions. If you want to stay with sixties technology, just ask Bear.
C'mom bear, just pulling your chain here. Have a sence of humer, It's been awhile since we "chatted"
"You do realize" that ford switched from champion to Autolite for a reason. right? I mean, the seventies and 2010 came around.
For a stock application, you cannot go wrong with motorcraft parts!
I say, buy em and use em, 9 out of ten give no problems in the long run.
Jeesh, we hijacked a thread and you called me a "bad" name over a difference of oppinion. MY dad's bigger than your's..LOL C'mon now. I appologize, I didnt think you would get this upset.
My dad's dead dummy. I have never seen an aluminum spark plug. I will bet I changed more plugs than you.
I had to remove a lot of old debris from the carb, one of the main jets was partly blocked (still need to remove all jets and clean with compressed air). Idle is much better now, surging almost gone, BUT : there is an annoying hesitation coming and going at constant speed, the car slows down / accelerates slightly, more prominent the slower I go. I can see a similar thing when looking at the vacuum gauge at idle, vacuum keeps "cycling" slightly...
Any ideas where to look? I plan to pull the carb and clean it completely, ignition seems OK.
