Rotella T
Rotella T
After reading the oil wars I still don't know what oil
to put in a 4.9 I6 with 300k on the clock.
Will Rotella T work or any body know what would be the best oil
for it .? I know about the filters just need to pick the rite
oil for this truck.
I run rotella T in all my other rides
but they don't have 300k on them.
The truck dose not smoke or burn oil.
If someone with "oil experience" would let me know which
would be best for the old truck i'ed sure appreciate it.
Thanks a bunch.
oil for this truck.
Thanks a bunch.
ZDDP is available for an additive. Brad Penn and Valvoline VR1 are racing oils and have the zinc. GM EOS was off the market for awhile but believe it's available again. STP in the red bottle works, but I haven't been able to find it. These are the only options I know of. I use the Valvoline VR1 myself, but getting the weight oil you want is a little harder to find. Advance store and most chain stores only carry 20w-50w, but it is made in other weights.
Follow the cam manufacturer's recommended additives and proceedures for break-in and one is good to go. Also, oil formulators have replaced the zinc with other additives.
All the panic-hype over the new oil formulations is just like the chatter over switching from leaded to unleaded gas. The predicted catastrophic engine failures didn't happen.
oil for this truck.
Thanks a bunch.
oil for this truck.
Thanks a bunch.
It's "diesel engine" oil, so it has more detergents, but it's backward compatible with gasoline engines.
And it still has zinc in it, just not nearly as much as in the old days. Plenty enough for long engine life.
I use Rotella T 10w-40 during the summer and 10w-30 during the winter on my 95 300. Engine has almost 220k on it and its not burning or leaking oil. In the past I have pretty much bought the best brand on sale that meets the OEM spec. and Motorcraft filter. Over the past 40 years of car ownership I have never had a lubrication failure. I always use the OEM filter and change the oil every four months or 5,000 miles.
Btw this truck just past my old 83 F150 in total miles for #2 on my high mileage list. Its a strong rust free truck in good condition and all of the repairs have been wear items with the exception of the MAP sensor.
regards
rikard
regards
rikard
