6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 6.4L F350 Thermostat Replacement
Old 10-29-2010, 11:13 PM
CSM_Master's Avatar
CSM_Master
CSM_Master is offline
I know this is not a popular topic as I found only one thread in almost 3,000 and it simply stated that doing it is a PITA. However, I am determined, and in the absence of a Haynes Manual am turning to the Forum for help.
I am of the understanding that there are 2 thermostats in the cooling system, and that they may have 2 different temperature ratings. Where they are located, what additional parts / tools I may need to replace them is my biggest question. As I use my truck for work, I cannot afford to have it down while I hunt for parts, etc.
If you could please provide photos, they would help me immensely as I am not wholly familiar with the lingo used in this forum.
Thanks for your help!
Old 10-30-2010, 07:23 AM
senix's Avatar
senix
senix is offline
Received 1,405 Likes on 1,001 Posts
I don't really know the answers but yes there are two thermostats, one opens first at a lower temp setting.
I would assume they will be labeled when you buy them and if you note the differences you should be able to match them up upon taking the old ones out.
You should also replace the upper hose at the same time. Those are quick disconnect type hoses on there. Orginal ones only had one 0-ring for sealing. New one has two o-rings.
114 ftlbs is there torque specs for the thermostat housing.
I am thinking that maybe you should inquire as to whether those bolts are a one time use as well.
Old 10-30-2010, 09:19 PM
CSM_Master's Avatar
CSM_Master
Thank you, Senix. Some helpful tips prior to diving in. I had never considered "one time use" bolts. Any idea what temp the thermostats would be rated for? When I visited the AM supplier, they only had one type listed in their system for this model.
Thanks for your help.
Old 10-31-2010, 06:36 AM
senix's Avatar
senix
senix is offline
try Ed at www.partsguyed.com, sponsor of this site. He will know.
Old 10-31-2010, 08:22 AM
stevestroke01's Avatar
stevestroke01
stevestroke01 is offline
That torque spec should be 114 lbf/in or 13Nm.
Old 10-31-2010, 04:23 PM
CSM_Master's Avatar
CSM_Master
Thanks to both of you. I'll be certain to check the link out.
Old 10-31-2010, 06:30 PM
Tom's Avatar
Tom
Tom is online now
You are out of your 100,000 mile engine warranty?
Old 11-01-2010, 01:56 AM
CSM_Master's Avatar
CSM_Master
Hi Crazy001. Yes, I am well beyond the warranty mileage.
Old 11-01-2010, 03:24 PM
BASSHUNTER's Avatar
BASSHUNTER
BASSHUNTER is offline
Good call on the upper rad hose! I was just on a 1000 mile trip and mine started leaking antifreeze everywhere.Got a new one replaced(Not under 36000 mile warranty dammit) The service Mgr advised me of the new 2 oring hose assy,said he hasn't seen one of the new hoses leak yet but has had alot of the other ones go bad.
Old 11-01-2010, 10:55 PM
CSM_Master's Avatar
CSM_Master
Hi All,
I already replaced the upper hose. The gasket melted and started to leak while I was traveling through phoenix in 100+F while towing my travel trailer. Only thing to go wrong on the truck during a 16,000 mile road trip!
Does anyone know where the thermostats are located, and how to replace them? Again, pictures would be appreciated.
Thanks
Old 11-02-2010, 01:58 AM
TIRE FRYER's Avatar
TIRE FRYER
TIRE FRYER is offline
I also had the upper hose leak(seep) on mine. Only noticed it when I went under the truck to look. Also found a new tsb ford has about hyperextended thermostats. They claim that builds up pressure and causes the radiator to leak. Probably the answer to all of our radiator problems.
Old 11-03-2010, 10:55 PM
harris2108's Avatar
harris2108
harris2108 is offline
T-stat Removal
I removed the upper radiator hose and EGR cooler to get them. If I remember right the T-Stats are shaped differently so that you can't get them mixed up.
For sure an SOB, took me 5 hrs and 3 or 4 bloody knuckles.
Old 11-04-2010, 07:53 AM
koboss1's Avatar
koboss1
koboss1 is offline
Send me your email and I will send u picks I have 6.4 on a crate in my shop easy to see
Old 03-05-2014, 12:34 AM
durbs21313's Avatar
durbs21313
durbs21313 is offline
Andrewdurbin29@gmail.com
Old 03-05-2014, 12:27 PM
rjlabonte's Avatar
rjlabonte
rjlabonte is offline
Try these links.
You can search further and probably find exactly what you are looking for. Good luck, let us know what you find and how it goes.
Quick Reply: 2008 6.4L F350 Thermostat Replacement
