I will pay you real money if you can find this part!
Old 01-05-2017, 07:07 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
02GrayPowerStroke is offline
I need the transmission (E40D) wiring harness for a 1999 F250 5.4l single cab long bed 4x4. I have looked every where. I will pay you $50 if you can find one in good working order. Please ask if I did not give you all of the information needed.
Thanks!!
Old 01-05-2017, 10:25 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Need following information if possible.
1. Tag number on the harness. It will be very expensive if found new.
2. What is the exact problem?
a. Burnt, broken etc.
b. Why it cannot be spliced color code to color code clean end to clean end splicing.
So far you really have not given this info.
Good luck.
Old 01-06-2017, 01:33 PM
02GrayPowerStroke
the harness it totally destroyed. i have no o2 sensors and no tranny communication. i can not find the tag on the harness
Old 01-06-2017, 02:42 PM
Tom's Avatar
Tom
Tom is offline
Check out Car-Part.com--Used Auto Parts Market and search for a transmission by zip code. Call the yards that have transmission listings for your truck and ask about the harness. Sometimes they list parts before they've been pulled, so they may have the donor truck handy to pull the harness out of.
They will probably even take a look for free.
Old 01-06-2017, 08:36 PM
kd4gij's Avatar
kd4gij
kd4gij is offline
you may have to get the complete under hood harness. http://www.ebay.com/itm/NOS-1999-For...-/322317185036
Call your local ford dealer parts give them your vin and what part. They will give you the part # even though it is obsolete.
Old 01-08-2017, 02:50 PM
jelder's Avatar
jelder
jelder is offline
So is your truck a SD or a LD F250
Old 01-09-2017, 07:32 AM
02GrayPowerStroke
its a ld 250
02GrayPowerStroke
1997 - 2003 F150
02-05-2017 06:41 PM
02GrayPowerStroke
1997 - 2003 F150
01-05-2017 01:01 PM
Tom
07-25-2015 03:38 PM
shawn11762010
01-07-2012 09:24 AM
bucks77ford
02-17-2007 06:58 PM
Quick Reply: I will pay you real money if you can find this part!
