COOLANT FLUSH AND FILL - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-29-2010, 06:18 PM
FSJ-EARL FSJ-EARL is offline
FSJ-EARL is starting off with a positive reputation.
It is starting to get a bit chilly here in Central PA, I want to do a flush and fill of my radiator, but I am hearing / reading all kinds of things about the proper coolant/ anti freeze / additives/ corrosion / cavitation and all kinds of stuff I don't really understand. Does somebody have a really good write up or description of what to do, how to do it, what to use, etc.? THANKS IN ADVANCE!
Old 10-29-2010, 06:48 PM
binuya's Avatar
binuya binuya is offline
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
Old 10-29-2010, 06:51 PM
eetalt eetalt is offline
eetalt is starting off with a positive reputation.
Coolant flush
I went through this decision-making process after doing a search on coolant on this forum and decided to go with the Cat ELC in my '99 PSD here in North Carolina. It looks like a good product and I like the product effective lifespan.
Also, you might want to look at Gooch's coolant flush write-up here: Ford Super Duty Coolant Flushing Procedure | Superdutypsd.com. As he says, the PSDs came with either the green coolant which requires monitoring or the Ford gold coolant. The big deal for changing coolant types is to do a very thorough flush of the system before putting in the new coolant.
Old 10-29-2010, 07:18 PM
Wow, this is quite the job. What is a "degas" bottle, and where do you get all these types of coolant?
Old 10-29-2010, 07:26 PM
150ford 150ford is offline
150ford is gaining momentum as a positive member of FTE.150ford is gaining momentum as a positive member of FTE.
I had mine done at the dealer. Didnt have time to do it myself. Cost me about $100.00. I try to change it every year or two. Its pretty important on these diesels.
Old 10-29-2010, 07:55 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
The degas bottle is your radiator overflow reservoir.
Check out the yellow pages of your phone book. Look up "Oils Lubricating" and it should give you a list of point-of-sale petroleum outlets in your area.
Stewart
Old 10-29-2010, 08:02 PM
01EX 01EX is offline
01EX is gaining momentum as a positive member of FTE.
Excellent link binuay
Thanks for putting it out there.
Old 10-29-2010, 08:51 PM
Stewart_H's Avatar
I'm kind of partial to that link too.
Gooch's flush procedure is carried on almost all diesel enthusiast forums, but the link I put together includes a bunch of Gooch's coolant info that I haven't ever seen posted in one thread.
I culled all that info from various threads and posts by Gooch from over the years and saved it to my hard drive. I checked with Gooch before posting the info, since it was several years old, and he said it was still current and correct.
I've done a bit of research into ELC's and everything I've found backs up all of Gooch's info.
Stewart
Old 10-29-2010, 09:08 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
CAT ELC user here too Earl but Fleetguard ELC is another good one, just make sure to read the containers for HD trucks. Check your local truck stops too, there pretty cost consience. Its a process to change out the coolant but you'll never have to do it again.
Coolant flush advice Marioj87 2004 - 2008 F150 2 07-15-2016 10:15 PM
Coolant Flush Questions jajones1988 1999 to 2016 Super Duty 2 04-22-2014 12:51 PM
Restore and Restore Plus chemical coolant questions...did I not flush enough? Boo_Daddy 6.0L Power Stroke Diesel 12 10-29-2013 08:53 PM
Flushing Coolant GeneLaw1 6.0L Power Stroke Diesel 41 01-13-2012 12:49 PM
Coolant Flush onuredneck707 6.0L Power Stroke Diesel 18 08-31-2011 11:24 PM
Tags
2003, 2005, 96, chaange, coolant, diesel, e250, expedition, f150, f250, flush, ford, goochs, procedure, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
