Suspension Castle nuts, re-use or pitch'em?
I've got my outer tie rods off right now doing repairs, but am just about ready to put a new set on. The short outer tie rod came with the zerk, castle nut and cotter pin, the long side did not, but had the zerk already installed. Can i re-use the old castle nut (* new cotter pin of course).?
From an engineer's perspective:
The default answer is "replace all fasteners when parts are replaced".
There are a couple reasons for that:
- Some fasteners are torqued slightly beyond their yield limit during proper installation (like the head bolts). This weakens them slightly, so multiple re-uses would become a problem.
- There are a LOT of clueless gorillas out there grossly over and under torquing fasteners and ruining them. But even though we are far from able to control them, we engineers get blamed when they screw things up.
- Some nuts are deformed slightly to be self locking. Each time they are removed or installed, they lose some of the deformation and don't lock as well. These MUST be replaced to provide proper locking function.
But in this particular case:
- A tie rod castle nut should never have been torqued beyond yield point, and they are not self locking.
So if you are confident NOBODY had previously under or overtorqued them, you should be quite fine to re-use them.
V8SHO
01-21-2023 09:27 AM
tuxedobuttonquail
66
09-19-2016 03:19 PM
blk450er
06-25-2016 12:55 PM
blackjack33
05-12-2016 04:06 PM
Pridnjoy
1999 to 2016 Super Duty
11-29-2015 11:39 PM
