Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape & Escape Hybrid
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
  #1 (permalink)
Old 10-29-2010, 12:28 PM
Jaimecj Jaimecj is offline
Garage is empty, add now
Jaimecj is starting off with a positive reputation.
2003 Ford Escape....RPM problems and battery light coming on occasionally!!
For about a week now I have noticed my battery light going on and off. As of yesterday, my RPM's are now dropping for no reason. I'm staying at the same speed, and my rpm's drop down to 2....when they should be at 3. Its like the needle is floating and continuously dropping! I'm not hitting the brake, or taking my foot off of the gas pedal. I had both battery and alternator tested, and they are fine. Has anyone had this problem, or have any idea what could be wrong?
Thank you!
  #2 (permalink)
Old 11-08-2010, 09:14 PM
tonyford tonyford is offline
tonyford is starting off with a positive reputation.
You don't state if you have an automatic or manual transmission. If's an automatic trans, the trans may shifting in and out of gear causing the drop and rise of rpms. But that does not explain the battery light.
You can do all kinds of speculating on what the problem is or problems are. Could even be a fuel problem and the engine is starving for fuel causing the rpms to drop so low at times it is affecting the battery charging.
I would bring it to a reputable mechanic, if not Ford itself.
  #3 (permalink)
Old 11-12-2010, 07:02 PM
CSFord CSFord is offline
CSFord is starting off with a positive reputation.
Battery Light coming on may just be a sensitive sensor..no worries. Just keep an eye on it as battery may be getting a little weak.
  #4 (permalink)
Old 11-13-2010, 03:38 PM
squid111 squid111 is offline
squid111 is starting off with a positive reputation.
get them retested or do it yourself
the cheap get the battery tested!
the expensive the alternator is going?
if you have a multimeter:
a> set the voltage to dc
b> check the battery with the engin off< you should have around 12 or better
c> start the engine a test the alternator voltage should be above 13.5
pray for the battery
squid111
  #5 (permalink)
Old 11-15-2010, 09:11 AM
martin_csr martin_csr is offline
martin_csr is starting off with a positive reputation.
You might be able to use the odometer display to check the battery.
Insert the key into the ignition switch, but don't turn it.
Press & hold down the odo buttton, then turn the key to the ON position w/o starting the car... continue pressing the button.
When tESt appears on the odo display, release the button.
The gauges will do a sweep & the display will change to GAGE.
Now press & release the button to cycle thru the various displays until you get to the bat display - it should show the engine OFF voltage.
Now start the car - the engine ON voltage should be displayed.
There are fifty or so items that can be displayed; the battery display is within the first 15-20 or thereabouts. Other items that are kinda handy: engine rpms, coolant/engine temperature. For kicks you can drive the car using the digital speedometer.
__________________
2002 Escape XLS 2.0L I4 5MT ~69,000 miles
Tags
01, 2003, 30, battery, drop, escape, f150, ford, gears, issues, jump, light, problem, problems, rpm, rpms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
