RADIATOR SUPPORT
The rad support will fit but you need to cut a few holes in it for the 67-72.
The inner fenders will fit but you will also need the 73-79 hinges and hood. The hinges on a 73-79 bolt on the opposite side of the 67-72. Also the reason for the 73-79 hood.
Someone else should chime in also but I think I got all that straight.
The 67-72 hood will work with the 73-79 hinges/inner fenders. You have to use the 73-9 cowl brackets with the newer inner fenders and they may need to have the mounting holes slotted to massage the fit. The newer rad support fits but as the hood latches are different you need to drill and mount j-clips to hold on the older latch design. Easy to figure out. Might as well go all the way and find a pair of the '77-'79 plastic fender liners and install them for more protection (some trimming required).
mike
mike
1967/72 & 1973/79: There are TWO different radiator supports.
With a Super Cooling radiator, the opening radius is much larger.
If you do not have a Super Cooling radiator, and you get a support for one, there will be no place to bolt on the radiator's mounting flanges.
The fan shroud used w/a Super Cooling radiator is also different.
matt2491
01-03-2016 04:23 AM
joegeds
09-30-2015 06:24 PM
mr.fordneck
10-20-2011 11:32 PM
falcon1964
07-11-2007 07:36 AM
