The early Jeeps use the same bolt pattern but the wheel offset is often all wrong for our trucks. You want a maximum of 4" backspacing for our trucks, that equates to 0 offset on an 8" wheel and -2" offset on a 10" wheel.
like others have said, they have to be older. the bolt pattern for our trucks is 5x5.5, while the "newer" jeep wheels if you will are 5x4.5.... i believe the 5 lug dodge wheels fit our too...
I know the suzuki sami 5 lugs will fit a 79 bronco. No back space issues. I bought them 12 years ago. They are 15x10.
I've heard some of the dodge trucks will fit but what years? Is there some place in a sticky that breaks down a list of what other things will fit a 5x5.5?
What vehicles have 17" wheels with the 5x5.5 bolt pattern? I would like to move up to a 17x10 if possible but I am cheap and want to use a stock wheel and not aftermarket if possible. What back spacing should these be?
I found a deal on a set of 35x12.5x15 wheels and tires. Does anyone know if jeep 5 lug wheels will fit on a ford 5 lug? Thanks!
. My expedition has no front hubs to get in the way and have a set of after market Wrangler rims on it right now. I believe they came off a 2012 Wrangler. Just some slotted steelies but fit like a glove. Just thought I'd pass it on
