Fuel Pump pressures 1986 302 F150 - Ford Truck Enthusiasts Forums
Old 10-29-2010, 11:06 AM
66sprintw53 66sprintw53 is offline
66sprintw53 is starting off with a positive reputation.
I have a 1986 F150 4x4 302 EFI motor with dual tanks. I understand it has three electric pumps 1 in each tank (low pressure units?) and one on the frame rail (high pressure ?).
I am contemplating a switch to carb if I cannot get the EFI to run reliably. So, I am trying to find out the running pressure on the two in tank pumps and whether they could be used to feed a carb.
I know that the transfer valve is an issue too. I am wondering if anyone has tried this and how it turned out.
Thanks in advance
Chris
Old 10-29-2010, 11:56 AM
smashclash smashclash is offline
smashclash is starting off with a positive reputation.
switching to carb from EFI isn't going to solve your fuel delivery problem if that is the problem. do both tanks work? do you have an issues with fuel being directed from one tank to the other? have you changed the fuel filter?
Old 10-29-2010, 09:35 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I want to say the low pressure pumps are 9-10 psi, but I have no official source for that. If that's the case, it's still too high for a carb. Also a carb system "dead heads", meaning when the carb doesn't need any fuel, it stops the flow. All 3 pumps in your system are not designed to dead head, with no relief in the pump if it happened.
There are plenty of cheap electric pumps on the market though that would work, and are designed for a carbed system. You would just have to mount it on the frame somewhere, and take the pumps out of the tanks.
Old 11-02-2010, 05:42 PM
I am going to check to tank pumps first to see if they are working. I bypassed the relay and got the front high pressure pump to come on but could not hear either tank pump running. There was no gas making it to the front pump, so I think the problem is either in the in-tank pumps or the wiring. I have found the wiring schematic and will see if I can figure it out.
Just wanted to know if the EFI in-tank pump pressures were in the range of a carb'ed fuel pump. If they are 9-10 psi then you could probably use a regulator to bring it down to 5-6 psi and run a return to the tank using the factory steel line.
I would prefer to keep the EFI, but I do not want to chase all sorts of issues with a 25 year old system. Also that Dual Function Reservoir is a snake's nest. What a piece of art. Man, I hope it is working OK, but if not I may just run on one tank.
Thanks
Chris
EFI in tank pump dorymate88 Fuel Injection, Carburetion & Fuel System 16 07-10-2014 10:04 PM
1986 F150 fuel pump pressure Gene Beckstead 1987 - 1996 F150 & Larger F-Series Trucks 3 06-01-2014 11:03 AM
fuel pump pressure 1986 f150 Gene Beckstead 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 06-01-2014 07:43 AM
86 f150 efi to carb fuel pressure question Jordanz_03 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 03-12-2012 03:27 PM
'86 F150, carb or EFI? skemcis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 06-06-2010 11:11 PM
Tags
1986, 302, 86, f150, ford, fuel, high, location, loss, low, preasure, pressure, pump, truck, v8, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
