makeing a short box a long box ??
Old 10-28-2010, 07:23 PM
jg96powerstroker's Avatar
jg96powerstroker
jg96powerstroker is offline
ok so my 96 is every thing i want in a truck all but a long bed and a 5 speed! so i have a doner that i can cut the frame and use it and box on my truck even the same color, 2 go from auto 2 manual how big of a pain am i looking at??? i love my big black crewcab, but would really love her more if she was longer and could jam the gears!!! also how do i put picks on here??? i wanna show her off to you all! thanks
Old 10-29-2010, 06:53 AM
427 fordman's Avatar
427 fordman
427 fordman is offline
Lots of guys have done the auto to manual swap, do a search and you should find some threads. Redman (Jacob) just recently did it. Have you ever stretched a frame? Don't mean to be a butthead, just checking. I used to do it on big trucks. It can be done but needs to be done right.
I'd help you with pics but it took me a year to figure out how to and I'm no good at explaining anything to do with the computer. Something like download to photobucket and image post them here, that's as good as I can do..
Old 10-29-2010, 07:07 AM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
For pics go to the top and click Galleries and Manage/Create. Make a gallery with pictures in it, then after the pics are on there you can click below them where it says "Forum Codes", copy and paste in the post. Should start and end with [IMG] if it's the right code. You can do the same with pics in your "garage" on the lower top toolbar.
As far as switching to longbed, could you find a frame from a F350 crew cab long bed? It would be even better if you found a F350 4x4 because you would have the Dana 60 front axle instead of the TTB.
For the manual swap you need the ZF5 trans from a 88-97 7.3, flywheel and clutch for your year truck (Valair), pedals from a 92-97 F150-F350, and hydraulics from a manual PSD or 460 truck.
Old 10-29-2010, 07:18 AM
Fullcrew7.3's Avatar
Fullcrew7.3
Fullcrew7.3 is offline
Way to go Evan. Beans sent.
Old 10-29-2010, 07:19 AM
Brown Falcon
Thanks Dave. I'm gathering all the info that I can about this for when I swap the ZF5 from my '88 into my '95.
Also forgot to mention that there's some re-wiring you'll need to do for the neutral safety switch, reverse lights, etc. But Redman84 can help you with that when it's time.
Old 10-29-2010, 10:14 AM
Talyn's Avatar
Talyn
Talyn is offline
I don't suggest cutting and welding the frame unless you really know what your doing.
Be easier to find a donor frame IMO.
I know your pain though.
at least you have a big cab.
Old 10-29-2010, 07:22 PM
Krisx125's Avatar
Krisx125
Krisx125 is offline
Id give anything to make my Ext cab short box.
Old 10-29-2010, 07:38 PM
redman84's Avatar
redman84
redman84 is offline
I'd give anything to make my ext cab long box a crew cab long box...
Old 10-29-2010, 07:41 PM
427 fordman
yep, gotta love the long truck. No shortbox for me either. My dad had a fiberglass lid on his pickup with a shortbox and I called it an overgrown car, short box with a lid, can't haul nothing. He finally took the lid off.
Old 10-29-2010, 07:51 PM
redman84's Avatar
redman84
redman84 is offline
I couldn't agree more!! To each their own I guess. I won't be knocking on anybody who has one unless it was my dad too, especially if they don't do anything with the bed, but you'll never see one on mine. I LOVE my long bed. I can carry SO MUCH in it. It's nice to be able to put whatever in and close the tailgate and go. Heck we can stack plywood sheets til they hit the toolbox and close the gate. No crazy strapping and what not...
Old 10-29-2010, 08:13 PM
jg96powerstroker
i have already done front end swap when i put my lift on a month or so ago, i have streched dump trucks, by fish plateing the frame they all held up and haule more than i ever will, on the trany swap i have a 93 idi with add on turbo, can i use the wireing and trany and transfer from it??? was going to put it in my other 93 crew cab i barrowed the front end from but thinking it needs a ps in it!!!
Old 10-29-2010, 08:56 PM
KonaGrown's Avatar
KonaGrown
KonaGrown is offline
Not to Hijack,
Just wondering if anyone has tried putting suicide doors on our extended cabs?
Old 10-29-2010, 11:06 PM
Krisx125's Avatar
Krisx125
Krisx125 is offline
Well the thing is, i have a 2002 F-450 7.3 Flat bed..So anything and everything i need to haul/move i can use that. I really just use my truck as a car. So a short box would be nice. I mean its a daily driver and massive lol. Its alot shorter than my crew cab long bed i used to have tho...And im actually starting to miss that truck.
Old 10-30-2010, 07:38 AM
Brown Falcon
Yes, you can use the trans and t-case from the '93 (read my previous post) You can use your existing wiring for it, or might be able to use the '93 5-speed wiring, not sure. Send a PM to Redman84, he can tell you.
Originally Posted by KonaGrown
Not to Hijack,
I've thought about suicide doors on my crew cab...
Old 10-30-2010, 09:22 AM
triskadek's Avatar
triskadek
triskadek is offline
My long bed super cab doesn't do so well up here for urban cruising, the parking spots are ridiculously small. Narrow is bad enough, but they are so short I usually need two.
Quick Reply: makeing a short box a long box ??
