rubber fuel lines
rubber fuel lines
Guys, any problem with running fuel lines between the two metal lines that run along the frame and then up to the top of the motor? I replaced the metal lines that run up the front of the motor and the "quick disconnect" ends are no good anylonger and I want to just run fuel line if possible.
These aren't high pressure are they?
Just make sure it's rated to handle ULSD, and bio if you run that. I use fuel injection rated hose with a 30R9 rating that can handle bio also. Goodyear® Engineered Products :: Fuel Injection Hose SAE 30R9
My local autozoo sells it by the foot.
I have regular fuel hose to get me where I need to go this weekend. I will have to change it next weekend.
