4x4 solenoid replace with F150 - Ford Truck Enthusiasts Forums
Old 10-28-2010, 07:22 PM
kidoo kidoo is offline
kidoo is starting off with a positive reputation.
Hi, I think my 4x4 solenoid does not work properly. I checked it with the tube that goes to the 4x4 blocked off so I do not loose the air because I have a leak at the right wheel. ( My 4x4 does not work obviously)
The valve flickers when I select the 4x4 button but then after 15 to 30 seconds, it bleeds off by itself. It does not seem to hold. Is this normal?
I checked the price today, they want 124 dollars for it but the ford F150 is only 34 dollars. The 150 valve is a smaller unit and it has only 2 wire prung. The diesel one is bigger and has 3 wires to it. As the dealer told me, the F150 has two solenoid, I would use only one.
I think the valve only gives a go or no go for suction, then when we disengage the 4x4, it bleeds off the air for a short time to let the air come out of the 4x4 to disengage it, then it would relock the air so we still have the heater working and the accumulator to rebuild the vacuum. I wonder if the third wire would be to give a signal to momentarily disengage de 4x4.
Old 10-28-2010, 07:26 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
If you have the part #, you can get it cheaper a number of places on line.
You can also get in touch w/ partsguyed.
Old 10-28-2010, 07:30 PM
Ok, I will check the part number, I thought I could only buy it at the stealer.
Old 10-28-2010, 09:07 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
FTE sponsor PARTSGUYED.COM = Ed Olson, parts manager of Horizon Ford in Seattle WA
Ed gives parts discounts to all members off the actual MSRP.
You will not find an actual Ford part number on any part after 1956. The only numbers found on parts after 1956 are either ID engineering, or casting numbers.
In this case, it will be an ID number...if applicable. Online sources usually do not list ID numbers, only actual part numbers.
Ed has an EZ to use online parts catalog where the MSRP and discounted prices will be listed once you find the part you're looking for.
Usually I could look the puppy up and list alla this jazz, but I have no parts catalogs after 2001.
Old 10-28-2010, 10:38 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
You need to ask questions in the F-150 forum first and find out how the solenoids are supposed to work. If it's anything like the F-250, it is a pulse lock/unlock. There is not vacuum applied at all times. Vacuum is only applied during the lock and unlock cycles.
Old 10-29-2010, 03:51 PM
Ok, once the 4x4 is engage, it would simply hold there. There is no suction at all time up until it free up the air lock in the wheel when you disengage it?.
Old 10-29-2010, 05:13 PM
On an F-250/350/450/etc, yes. A vacuum pulse locks the hubs, another vacuum pulse (less vacuum than the first) unlocks the hub.
Edit: OK, I'm confused. Are you talking about an F-150 or not?
Old 10-29-2010, 05:20 PM
Yes I have a F350 and was wondering if a F150 solenoid would fit on my F 350.
The problem with my solenoid is that it does not seem to hold, the solenoid operate but after say 15 to 45 second, it let all the air out. Then the pump is always working.
The F350 solenoid is $124.00, the F150 is $34.00
Old 10-29-2010, 11:10 PM
From what you describe, the F-150 solenoid will not work.
If the vacuum pump is always running, then you have a leak somewhere between the pump and the solenoid, or the solenoid itself. Try removing the solenoid hose and plugging it and see if the pump eventually stops. It might take a minute.
Old 10-30-2010, 08:49 AM
It seems that there is a leak at the solenoid, if I plug the line after the solenoid, the pump never stop.
Old 10-30-2010, 10:16 AM
Then you need to replace the solenoid.
You can try http://www.partsguyed.com. He often has parts cheaper than the dealer.
Old 10-30-2010, 10:59 AM
cak301 cak301 is offline
cak301 is starting off with a positive reputation.
You can get a used one at a salvage yard for 30-40 bucks. They usually guarantee them for 30 days or so.
Everything You Wanted To Know About The IWE System...And Then Some xjcamaro89 2004 - 2008 F150 404 01-03-2017 01:59 PM
2003 F250 4x4 ESOF sometimes engages, sometimes wont engage chris2888 1999 to 2016 Super Duty 5 01-25-2016 10:15 AM
2005 F150 4x4 Noise/Troubleshooting nfazer 2004 - 2008 F150 4 12-07-2014 11:19 PM
PVH(vacuum) solenoid HELP Tact 1999 - 2003 7.3L Power Stroke Diesel 16 05-30-2014 04:46 PM
Starter makes a lot of racket heavy_d 1987 - 1996 F150 & Larger F-Series Trucks 16 03-21-2014 01:21 AM
Tags
150, 1999, 2003, 2004, 2007, 4x4, 97, f150, ford, location, replace, solenoid, truck, ware, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
