Cams and torque converters
I'm looking at cams and have a question about torque converters, at what amount of cam duration do you have to have a stall converter? Looking at various cam makers, some say at this duration you need one while some other maker will say you don't. Anybody got a clue? The cam I'm running now has 214 @.050, doesn't need stall, so, how much duration can I go with the stock converter? Thanks
Robert
Robert
on
1 Post
Robert
Robert
You dont want to use a Big Azz roller cam with stock heads..stock exhaust logs , stock intake etc..and valvetrain..you'll never get it to work.. If your just looking for a little bump in your idle..run something like the Comp Cams 272H...I believe that cam will run with all stock valvetrain.. Of course hedders and intake are always a plus along with a better carb.. If your planning on using it in a truck that tows..Use an RV cam in it..where it will drop the Tq range down low in the rpm band for good off idle towing with a stock conveter...Alot of research has to go into picking the right cam..Most just Pick one off the shelf because they have heard someone else is running that cam..and it could be completely wrong for there build !
Two things, all converters "stall" - the "stall" RPMs are the point at which, if the vehicle is not moving, and full engine torque is applied, the engine will rev to. So, if you want to figure out basically what "stall" your current converter is, push on the brakes as hard as you can, apply parking brake, and bring the engine RPMs up until they don't climb anymore. That's your current converter's "stall speed", give or take.
A lot of people have good luck bringing their existing converter to a speed shop who knows what they are going, either getting it rebuilt to what they want, or the shop will figure out what converter you currently have, and go slightly higher if necessary.
But like Russ said, it all depends on what you are going to be doing overall.
What weight vehicle? What rear gears? What tranny (assuming C6)? The list goes on and on...
Also, this has a lot to do with racing. If you're just rebuilding the engine with a slightly bigger cam and you're not concerned about 1/4-mile times, and just want a daily driver that works well, the stock converter would probably suffice. But again, if you are going TOO big on the cam, low-end torque will suffer and it will struggle to get moving.
fastwrx05
10-01-2007 11:17 PM
Jrock909
05-25-2006 02:30 PM
booneyrat75
13
12-14-2004 01:00 PM
