Getting Access to ABS Module (1999 Econoline 150)
My ABS light is on. I think it is a loose connection at the ABS module. (Long story I won't bore you with).
It seems the ABS module is attached below the Hydraulic Control Unit and very hard to get to. I am sure I have to move the HCU but it has a few hydraulic tubes connected to it and I can't remove those (cost for dealer to bleed the system) nor do I want to break one.
Does anybody know if things can be loosened up enough to get at the ABS module without damaging the HCU connections?
Thanks In Advance,
Pete
<!-- / message -->
Thanks In Advance,
Pete
<!-- / message -->
kawika
13
07-14-2007 12:49 PM
