I understand Bill. I can make the run of the mill lines, cut flare bend, no problem. The issues are the steel lines with the large hex transition nut that goes through the frame, like the picture I posted. The line is brazed (looks like silver soldered) into the side of it. It isn't a normal line. If they were just normal brake lines I would certainly bend them.
heavytruckparts.net and if your anywhere in ohio i know a junkyard with what looks like a semi nice 80's f600. That websites expensive, but youll find everything.
I ended up removing the old lines from the hex blocks and cleaning them up and silver soldering new lines into them. The rest were just regular cut flare and bends...
