1995 F150 4X4 transmission ID
Brand new member here--thanks in advance for any help. I have a 1995 F150 4X4 Eddie Bauer with auto tranny. I'm trying to determine what transmission I have. The tag on the transmission is unreadable. The emmissions controls tag lists it as code E. I suspect it is a E40D. What's the difference in a AOD, C6, and E40D? I need to replace the pan gasket and am trying to determine the fluid quanity.
Thanks, Bob
Thanks, Bob
This decoder should help you out: Ford Door Sticker Decoder .: Articles
I also like this photo for the pan shape and number of bolts:
E4OD is an electronically controlled 4 speed overdrive transmission. The C6 is a mechanical 3 speed transmission. An AOD is a 4 speed overdrive transmission that is also mechanically controlled.
The E4OD would require some type of electronic controller if was installed in a vehicle that did come from the factory with one. The C6 is controlled via a vacuum modulator and control linkage attached to the throttle. The AOD also uses a cable/linkage attached to the throttle to control the internal pressure.
More good reading here: Ford Transmission Spotter's Guide .: Articles
crossy
12-02-2016 09:10 PM
pilot47
10-06-2015 06:51 PM
rubberman56
04-02-2015 02:52 PM
southcoast
06-08-2011 02:03 PM
