Road Armor bumper is here!
I like it.
However there should be a requirement to having one. You should have to be able to hold it in place with one hand and bolt it on with the other in order to have one. I see you're using a hoist there. That way people will know your ***** match the ***** of your truck and your truck is not just compensating for tiny *****.
Like when I change my tires, I lift one wheel up, put a block under it, use a screw driver with 14mm socket on it, loosen the 8 lugs, take off the tire, poke a hole in it with my finger to release the air, rip the tire off, put the new one on, put the valve stem in my mouth, blow to 70lbs (had to make a special adapter to be able to do this), put the tire back on, finger tighten the lugs, cause i don't want to go past 100ft/lb, pick the corner up, take out the block, and let it down. Don't even get me started on engine swaps...
The 1st attempt was without the engine hoist...that lasted approx. 45 seconds.
And today, my back is on fire.
