ford n 500 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
ford n 500
Old 10-27-2010, 07:51 AM
ricevilian ricevilian is offline
ricevilian is starting off with a positive reputation.
ford n 500
i got a ford n 500 go to "ford n 500" on this site (gallery)for photos. you can see i made a big bad pick up truck out of it. am still working on it but this thing has got a 6.20 rear end in it, am resurching a gear change. it has 6 bolt w/ 825 20 wheels i have seen f600 with 5 bolt nothing with 6. this really seems to be a odd ball unit as a coe and "N 500" i just cannot find out anything about it. is it a 1 3/4 ton or 2 ton or? 39 inch tall wheels at 3000 rpm she is doing 55 mph. as it has a industrial 330 cu in v8 i think wide open is around 4000 rpm, any way did they ever make a two speed rear end for this truck. where can i find more info on this unit? I am in the need to know.thanks
Old 10-27-2010, 10:19 AM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Not bad I think. Would take some getting used to as the bed don't fit the cab shape to well. But nice work. There's a cab and chassis like that down the road from me. Now I need to go check it out better.
Old 10-27-2010, 10:47 AM
filler forn n 500
there is a fiberglass filler between the cab and box that moldes in it and shapes it to the cab and it looks great running board on box to fender also just not done yet. doing it as i can get time. interior seat and headling done now for floor and doors.
Old 10-27-2010, 11:13 AM
Can't wait to see all that when done. I got to go and check out the one here and see what it is and if it's worth messing with now. I like the idea of a box behind that style cab for sure. Some ceder side boards would be of interest to me if I did that to try and blend it better I think.
Old 10-27-2010, 11:55 AM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
Quote:
Six lug wheels should be a lot more common than 5 lug as they changed from 5 to 6 in the mid 50s
Two speed axles were in most 600s and are easily put in the 500s
Old 10-27-2010, 01:43 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
When you go two speed shopping, search "eaton two speed" or similar to find info on the Eaton 2 speeds. Several ratio combinations were available. You want to make sure you get the right combo so you do get a taller "hi" than your current axle.
The other way to go is an OD trans, probably the NV4500, or a Clark OD.
FWIW, the 330 is kind of a pooch. It sounds like you might not be using this for massive loads or towing D8s or anything. So, I would run that 330 for a while, and repower with something like a 351w with a OD trans from a later model truck--serving suggestion, ymmv.
Good luck with it.
Old 10-27-2010, 03:03 PM
rbaker6336's Avatar
Quote:
Good luck with it.
A 351W wouldn't be repowering more like unpowering compared to a 330
A 351W is barely enough motor for a F-150
Old 10-28-2010, 07:49 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Nice truck
Old 10-29-2010, 05:09 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Welcome to FTE
Post the VIN and all the codes found on the Warranty Plate, all can be decoded.
The Warranty Plate is either located on the left door face below the latch, or on the inside of the glovebox door.
An N Series truck is not considered a COE = Cab Over Engine, since the cab is behind the engine, not over it.
Looking for an F600? There's one not too far away. On Route 74 near Andrews NC is a black 1965 F600 Custom Cab dump truck parked on the west side of the hwy (opposite side of the river).
It's been sitting there a long time. I spotted it while driving the back roads of NC & TN recently.
Old 10-29-2010, 06:28 PM
rbaker6336's Avatar
There is another one on the road that goes from Hayesville N.C. to Hiwassee Ga.think it is SR75.
That is of Route 64
Bill you were getting close to my neck of the woods.I'm about 10 miles south of where 64 crosses
Old 08-15-2013, 09:47 AM
N600 N600 is offline
N600 is starting off with a positive reputation.
Does anyone know who owns this red N600 or where it's located? I'm building one just like it and would like to compare notes. Thanks.
Quote:
Old 08-15-2013, 02:26 PM
The original poster of this thread has it. ricevilian Or at least had it when he posted.
Old 08-15-2013, 03:23 PM
Thank you very much. I hope I can track him down.
Old 08-15-2013, 04:33 PM
His last activity here was
Last Activity: 08-18-2011 04:56 AM
Click on his user name and there may be a way to contact him yet.
It's a cool truck but I can't get past the bed. It just don't look like it fits.
Old 08-15-2013, 05:25 PM
Thanks--I sent him a PM so let's see what happens. If the bed looks too wide I'm not afraid to slice it down the middle and take a few inches out. I don't want to do it but if I have to it should be easy since it's all flat.
Any idea what part of the country that red truck is from? I've been searching and eventually it will turn up.
Thanks for the help. Some smart people on this site.
The $500 F250 JP3 1973 - 1979 F-100 & Larger F-Series Trucks 261 Today 03:20 PM
Ninth Generation Body Style (1992-96/97) Turns 20 Years Old in 2012! FORDF250HDXLT 1987 - 1996 F150 & Larger F-Series Trucks 15 01-01-2017 04:50 PM
1952 Ford F-3 Build Mattie2294 1948 - 1956 F1, F100 & Larger F-Series Trucks 170 05-03-2016 11:41 PM
Another new to the scene with 56 F500- POS-F500 1948 - 1956 F1, F100 & Larger F-Series Trucks 80 10-05-2012 04:55 PM
1960 Ford F500 tire/wheel questions 60F500 Large Truck 24 07-16-2012 08:30 AM
Tags
1965, 1968, 500, 500com, bigger, f350, f600, ford, fords, n500, parts, series, truck, trucks, tune, v8, w330
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
