Door lock codes - Ford Truck Enthusiasts Forums
Door lock codes
Old 10-26-2010, 10:01 PM
VCEC71 VCEC71 is offline
VCEC71 is starting off with a positive reputation.
Door lock codes
Can anyone tell me where to find the doorlock codes? I bought a used 2004 F250 Powerstroke it had no owners manual or card.
Old 10-26-2010, 10:27 PM
bubba_78363 bubba_78363 is offline
bubba_78363 is gaining momentum as a positive member of FTE.
Go back to the service departmernt and ask them to do alittle researched base off your VIN number. Should have them to you in not time at all.
Last edited by bubba_78363; 10-27-2010 at 10:13 AM. Reason: correcting a drunk post
Old 10-26-2010, 10:47 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Try these:
There are three ways to find the code. One is a lot easier than the other and much less work if you have a good eye and great flashlight. There are some Excursions, F250 and F350s that have a different wiring system.
The first location to look is just above the right front kick panel; the RAP module is black in color with the numbers on the front (the same as the white module). If you look above the kick panel you can see it quite clearly without taking anything apart. If it is not at this location please follow the next step.
This part is not hard to do. You will need to remove the front cover under the steering wheel that says fuse box. (It has 4 plastic screws to remove) under the dash, the five (5) digit code is on the cream/white box behind the radio, look to the top right of the open fuse box cover through the wires. (towards the fire wall). At the back firewall, look for a 5 digit code on a sticker on a cream/white box. This is not easy but if you try every angle I promise it will appear don't forget to use a very powerful flashlight if you want to see it.
Note: The RAP module sometimes is covered by insulation making it almost impossible to see.
It is located on the firewall behind the radio just below the windshield.
The third way is a more time consuming job because you have to remover the stereo.
Once you do, look to the rear you'll be able to see the 5 digit code very easy. This process can take 2-10 minutes.
Also:
You will have to release the compartment on the right side of the steering wheel in your dash. Then there will be some insulation that you will have to push to the side. There will be a little black box on the firewall with a 5 digit number. I believe the number is printed on a white label. This is the factory code. Once you have that, you can enter it in then press the 1-2 and 3-4 buttons at the same time then enter in your own code. The truck will lock then unlock if you've done it right. Oh yeah - you have to do each step within 5 seconds of each other for it to work.
Old 10-27-2010, 05:18 PM
shinyconcrete shinyconcrete is offline
shinyconcrete is starting off with a positive reputation.
Does anyone have the list of number combinations that you can go through and try?
Old 10-27-2010, 05:36 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
No offense, but if there is such a thing I hope nobody posts it.
Our trucks are vulnerable enough as it is.
Old 10-27-2010, 05:43 PM
I know what you mean, but it is just a list of the obvious possible combinations of the 5 numbers on the keypad. Someone had one they made up a while back. It takes a little time to go through.
A pm or email would work for me.
Old 10-27-2010, 05:48 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Welcome to FTE VCEC71, bubba and shinyconcrete. You can try this, read through our Tech Folder located at the top of the forum. Scroll down to the very bottom and you will see Keyless Entry Code
If anyone wants SteveBricks code.....just let me know and I will Private Message it to you...
Old 10-27-2010, 07:15 PM
Sullid01's Avatar
Sullid01 Sullid01 is offline
Sullid01 has a good reputation on FTE.Sullid01 has a good reputation on FTE.
I used the info I found here on FTE - I found the easiest way was with a dental mirror and a flash light. I looked up in an area under the dash just behind the radio (it's about a foot up there). I found the numbers impossible to read without the mirror - no matter how much I dug around, my head just would not get in the right position. Ford will want about $100 to get this for you (unless they really like you).
Old 10-27-2010, 07:25 PM
hubler13f's Avatar
hubler13f hubler13f is offline
hubler13f has a good reputation on FTE.hubler13f has a good reputation on FTE.
My truck came with a keyless entry code card in the owners manual, but it doesn't have any key pads, figure that one out, I'm still scratchin my head about it.
Codes kbf1961 6.0L Power Stroke Diesel 7 10-17-2015 10:05 PM
P1335 Code i eat hybrids 6.0L Power Stroke Diesel 13 12-16-2010 11:24 PM
Code reader KCMAGERS 1994.5 - 1997 7.3L Power Stroke Diesel 8 05-08-2007 12:36 AM
Code Reader Codes & Problems Quantrex Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 09-02-2002 06:53 PM
engine codes larbera76 Ford Inline Six, 200, 250, 4.9L / 300 4 04-12-2002 07:35 AM
Tags
2010, code, codes, combinations, company, doir, door, entry, find, ford, hot, keyless, lock, motor, read, truck, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
