3V 5.4 Gas Mileage - Ford Truck Enthusiasts Forums
3V 5.4 Gas Mileage
Old 10-26-2010, 09:06 PM
dfboothe dfboothe is offline
dfboothe is starting off with a positive reputation.
3V 5.4 Gas Mileage
I'm looking at selling my F250 with the 2V 5.4 for a F150 with the 3V, is there better gas mileage to be had by downsizing? will it be a better truck overall? thanks for any information
Dfboothe
Old 10-26-2010, 09:08 PM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
I don't really track my mileage, but I get between 15.5 - 16.3 MPG with my 04' 4x4 Supercrew if that helps....
Old 10-26-2010, 09:28 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
I'm not easy on my truck, meaning I don't overly baby it. It's not uncommon for me to take it to 3-4k leaving the line. My documented mileage in the short time I've owned it (almost two months) is 14.24 mpg average.
That's 9 fillups, hand calculated, over 2,155 miles.
This is 60% city, 40% highway
Old 10-26-2010, 09:47 PM
GwarForAll1021's Avatar
GwarForAll1021 GwarForAll1021 is offline
GwarForAll1021 is starting off with a positive reputation.
there is a gain to be had. your going to a newer (better) [depends on who you ask] motor, in a lighter slightly more stream lined truck. power per ton will be better so your foot will be out of the gas a lot more too.
it wont be like switching to a camery so dont expect to save the difference of a truck payment on gas.
i live in the flat lands of Florida with the scorching summer heat.
news to me is i get better mileage in the summer! around 14-16.
winter im getting 12-14. thats also being nice. when i drive like a pissed off teenager it drops to 9-10. at best.
the truck does do amazingly well on the interstate with a whopping 18 miles per gallon at 70 MPH. any faster and it drops to 14 quickly. 7 mpg at 125 =}
simply put i average 400 miles a tank at 30+ or so gallons.
Old 10-26-2010, 09:58 PM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
yeah, you'll see a pretty big improvement over your Superduty. A 04+ F-150 is pretty much all around more truck than the 98-01 F-250.
The motor alone will make you happier. I had a 4x4 SuperCrew (4 true doors) that could get upwards of 20 mpg highway. 12-13 with 100% city. mainly depends on how hard you drive her and your gas quality + the terrain. Mountains are going to kill MPG's
are you going to need a F-150 for load hauling that you utilize the F-250 for right now?
Old 10-26-2010, 10:00 PM
thanks guys, i'm thinkin that it'll be better, i do a lot of driving at 55-70 and i average around 12-14 no matter what, is the thought that 15-17 on the highway is a good thought with a 4X4 with 3:73's?
Old 10-27-2010, 12:23 AM
edwardlloyd's Avatar
edwardlloyd edwardlloyd is offline
edwardlloyd is gaining momentum as a positive member of FTE.
Quote:
Have you thought of the F150 HD 8200lbs? I have one, it's like half way between a F150 and a SD. It's only available in one configeration, supercab 8" 5.4. I've got a 2005 and it gets great mileage.
Old 10-27-2010, 01:10 AM
i hadn't even heard of a F150 HD, i'll have to look into that, i really don't haul much, 3 bike dirtbike trailer and a 16 foot car trailer with a tractor on it every now and then and that only probably weighs 4500 altogether , stepping down to a F150 sounds like a good move for myself, i'm 18 and in college right now, so better gas mileage will be nice, any thoughts on a good cab and drivetrain configuration, i definitely want 4X4 as I like the stance and occassionaly need it for setting traps and into some dirtbike tracks, thanks for all the help guys
Old 10-27-2010, 01:17 AM
429unibody's Avatar
429unibody 429unibody is offline
429unibody is gaining momentum as a positive member of FTE.
I just drove 403 miles 650 klicks, with my 08 F150 5.4 with a full load, Steel sled deck Whole Bull moose 900 feet of 5/16 cable and rope all my hunting gear and I still have 1/4 tank left 135 liter tank 30 gal
Old 10-27-2010, 03:34 AM
Tylus's Avatar
this is what I was talking about earlier
when "stock"...20 mpg highway @ 60-70 mph over longer distances.
when supercharged...well, it got 12.5 mpg with 100% city driving and rubber roasting. sorry, no highway mileage in this setup.
4x4 with 3.73 gears on 32" tires. every bit of 6,000 lbs with a 8,700 lb tow capacity
sounds like a 04+ would fit your needs. A HD F-150 would be pretty awesome as well. they have 4.10 gears from the factory
Old 10-27-2010, 06:28 AM
MCDavis's Avatar
My truck is the 4x4 with 3.73s and yes, that's generally about the range I'm in on a tank when I'm not on it hard. Best tank thus far was 16.66 which was 80% highway (75mph) and 20% city.
Old 10-27-2010, 07:14 AM
2002sport 2002sport is offline
2002sport is starting off with a positive reputation.
I got a supercab 4x4 with 3.73's. I get average 15.5-16. I had an '02 2 valve with 3.55's before, it got 13-14. I would say if you moved up to a 3 valve, and minus the weight of the larger truck you'd see another mpg or two than what I did. Most of my trips are 10 mile trips to town, then a bit of city driving.
Old 10-27-2010, 10:02 AM
thanks for all the help guys, i think i'll go with a 4X4 04+ F150, that'll pull everything i need it to and still get good gas mileage when i'm not pulling, i've heard on the 04's that there are some problems with the cam phasers? is this easily fixed? i already know of the sparkplug problem, but i'll prolly knock that out when i first get the truck so i know its fresh and i can see what it looks like
Old 10-27-2010, 04:58 PM
2Fords1Jeep 2Fords1Jeep is offline
2Fords1Jeep is starting off with a positive reputation.
Quote:
FYI, these trucks have a 4.10 rear. I have one (4x4) and the mileage isn't very good, around 12 mpg.
Old 10-27-2010, 05:33 PM
1bad67sbf's Avatar
1bad67sbf 1bad67sbf is offline
1bad67sbf is starting off with a positive reputation.
yeah the cam phases are a bitch but i think the late 06 and up have a better design and less problems and i think the late 07 and up dont have the plug problems as bad. get a super crew 4x4 and if its 80,000 miles or more try to get one with proof of spark plug changes already done.
Bad gas mileage 2006 5.4 BBpwer 2004 - 2008 F150 27 11-09-2015 12:43 PM
Whats the most mileage on Ex? USMC616 Excursion - King of SUVs 105 05-10-2014 04:09 PM
7.3 or 5.4? Texas Chain Ring 1999 to 2016 Super Duty 83 04-29-2013 07:19 PM
Strut Studs/Leveling Kits dfboothe 2004 - 2008 F150 11 07-07-2012 05:36 PM
Expedition 4x4 Gas Mileage WesternKyNobody 1997-2006 Expedition & Navigator 41 06-17-2010 09:40 PM
Tags
2006, 373, 3v, 54, f150, ford, fords, gas, gears, high, improving, jrnation, mileage, miles, mpg, supercrew, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
