Check Susp light on 97 Expedition EB - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 10-26-2010, 08:02 PM
1997 Expedition EB 1997 Expedition EB is offline
1997 Expedition EB is starting off with a positive reputation.
Recently bought an 97 Expedition EB that had the air ride replaced with coil springs, does anyone know how I can get rid of the check susp light?
Old 10-27-2010, 11:47 AM
dirtmonkey11's Avatar
dirtmonkey11 dirtmonkey11 is offline
dirtmonkey11 is starting off with a positive reputation.
I am 100% sure, but you can try to remove the sensor fuse, if its still there and maybe that would make the light go away. I am pretty sure the light is either controlled by its own control unit or through the pcm. Again I am not sure but these are just some random guess'.
Old 10-27-2010, 06:42 PM
WALJON WALJON is offline
WALJON is gaining momentum as a positive member of FTE.
I replaced my front air shocks with a kit from Strut master in the instructions was how to delete the light I had to take my dash apart to get to the wiring and cut a wire so maybe if you do a google search on strut master how to install one of these kits you may stumble on this info.
wish I could tell you what wire and where but it has been awhile
Old 10-27-2010, 07:35 PM
ok thanks, I'll give it a try. I also heard I can just remove the bulb in the dash.
Old 10-28-2010, 08:27 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Quote:
Some have just located the correct wire at the suspension switch and cut and taped it. I don't know which wire to cut though.
Old 11-07-2010, 01:12 PM
r2millers's Avatar
r2millers r2millers is offline
r2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud of
suspension lt
did you flip the air pump switch off and then back on under the passenger side dash? That light comes on when there's a malfunction in your air suspension system. Mine came on when a leak kept the air compressor kicking on and overheated it.
Old 11-09-2010, 12:55 PM
RoyalWitCheese RoyalWitCheese is offline
RoyalWitCheese is starting off with a positive reputation.
Remove fuse for the air compressor.
Remove Radio trim.
Loosen dash cover.
Locate Air Susp control computer.
Remove Air Susp controller screws.
Cut and tape the Dark Green with Light Green striped (on grey connector)
Turn ignition to Run - Verify light is off.
Reassemble.
Air susp compressor runs more often? jprix 1997-2006 Expedition & Navigator 19 02-04-2016 11:54 AM
99 Expedition "Check Susp" Light Disable craftsmangary 1997-2006 Expedition & Navigator 4 02-20-2012 09:40 PM
expidition air suspension exporangerman 1997-2006 Expedition & Navigator 11 12-03-2009 06:12 PM
1999 EB Exp. Check Suspension light? cbbr 1997-2006 Expedition & Navigator 1 05-27-2006 09:04 AM
97 Expedition EB Compass gkateley 1997-2006 Expedition & Navigator 10 03-08-2004 02:38 PM
Tags
1997, 2000, 2002, 2008, 97, auto, check, dash, dashboard, expedition, f150, ford, light, remove, susp, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
