Indicated MPG Error
Indicated MPG Error
Is there a way to calibrate the indicated MPG so that the reading is more accurate? My indicated is optimistic by about 6%. Over about 3000 miles the indicated is 15.04 and the calculated is 14.21. Granted this is not great mileage but my truck scaled at 8970#.
2011 F350 6.7L CC KR 4x4 Dually
It's about as accurate as your fueling process. Can you guarantee that you are filling the tank to within ounces of the same capacity every single fill-up? Highly unlikely.
Filling up at the same pump every time, I have found like djjoshuad said that the fill capacity is relatively consistent and fills pretty close to full at the click of the nozzle. My 6.0 was a nightmare to get completely full. If I let the nozzle click off by itself and hang it up at that point, my hand calc has been within an acceptable deviance from the in-dash meter. My 6.0 was much the same way.
brider
27
07-02-2005 03:53 PM
