Help. What engine do I have?
I just traded two 4-53 DD for what I was told is a recently rebuilt 7.3L. I want to find more info on this engine but cant find anything based on the numbers on it. How can I tell what model and year the engine is? I need HP rating, Max RPM and basically all the info I can get. I plan on using it in a Marine application. How do I know if I can install a turbo?
Also whats the right way to refer to it?
7.3L IDI V8 International Diesel
7.3L IDI V8 Ford Diesel
7.3L IDI Navistar International
Numbers on the engine:
Top of the block
What I believe is the intake manifold part number: 1804357C4
RC1A
3D U2 U5 13373
96038R3
Front of the Engine
06251 /
446430C4
Again any information you can lend a hand with would be greatly appreciated.
Thanks
Top of the block
RC1A
3D U2 U5 13373
96038R3
Front of the Engine
06251 /
446430C4
Thanks
The oil fill spout is located on the IP drive gear cover.
Just to the right of the drive gear cover at the rear of the cover there is a flat place on the block between the drive gear cover and drivers side head.
Wipe the oil off and you will see the block serial number.
The first group of numbers will have either 69 or 73 in them.
69 would indicate a 6.9, 73 would be a 7.3.
Example, mine starts with 69D U2U and is an 87 6.9 block.
Picture better than words.
The blue circle around the temp sensor at 11:00 position, but before the silver valley pan is where the number is located.
6.9 NA HP 175
7.3 NA HP 185
Max RPM under load is usually around 33 or 34 hundred, same either engine.
Max RPM no load is usually around 3500, same either engine.
Turbo, sure, just keep the boost under 15 PSI on a 7.3 or 10 to 12 PSI on a 6.9.
The exact year makes no difference on the 7.3.
Mid year 85 to 87 6.9 blocks have some advantages over the earlier years.
Technically, 7.3 IDI Navistar International for the name.
6.9 NA HP 175
7.3 NA HP 185
on
I would guess that's a 7.3 since it has the solid state glow plug controller but that could have been retrofitted. You can also check by seeing what size socket fits on the head bolts. 7/16 means it's a 6.9, 1/2 means a 7.3
Adding a turbo shouldn't be an issue since many of us have been running them for years on our 6.9s and 7.3s.
<table width="100%" border="0" cellpadding="0" cellspacing="0"><tbody><tr><tr><td width="0" height="0"> <form method="post" action="ssrv.cgi" lang="en"> <input name="cmd" value="spell" type="hidden"> <input name="doc" value="" type="hidden"> <input name="name" value="" type="hidden"> <input name="word" value="I'm" type="hidden"> <input name="wordid" value="" type="hidden"> <input name="sg" value="" type="hidden"> <input name="slang" value="en" type="hidden"> <input name="intlang" value="en" type="hidden"> <input name="pos" value="43" type="hidden"> <input name="len" value="2" type="hidden"> <input name="text" value="Those are water cooled exhaust manifolds. I'm planning to install the engine on a boat." type="hidden"> <input name="problemid" value="46" type="hidden"> <input name="igproblem" value="" type="hidden"> <input name="ignoresp" value="" type="hidden"> <input name="ignoregr" value="" type="hidden"> <input name="igpossp" value="43" type="hidden"> <input name="igposgr" value="" type="hidden"> <input name="trg_url" value="http://www.spellchecker.net/spellcheck/sproxy_h2/sproxy.cgi" type="hidden"> <input name="trg_wnd" value="sp_ch_opener_window" type="hidden"> <input name="txt_ctrl" value="myEditor" type="hidden"> <input name="svc_time" value="1288149833995" type="hidden"> <input name="customerid" value="1:1u4Q8-FRRkc3-pPjhY-ObTAp2-b2j6t2-hoYfi-qbmeJ2-P2GxE1-xBAW-J39B94" type="hidden"> <input name="schema" value="24" type="hidden"> <input name="schema_url" value="" type="hidden"> <input name="spp_langs" value="" type="hidden"> <input name="last_svc_time" value="0.18 sec." type="hidden"> <input name="sessionid" value="1.6321688" type="hidden"> <input name="statinfo" value="1" type="hidden"> <input name="bnr" value="1" type="hidden"> <input name="ssrv_host" value="" type="hidden"> <input name="cust_dic_ids" value="" type="hidden"> <input name="settings" value="sproxy=0" type="hidden"> <input name="optionssp" value="" type="hidden"> <input name="owner_prefix" value="parent.opener" type="hidden"> <input name="close_type" value="" type="hidden"> <input name="relaxedDomain" value="" type="hidden"> </form></td><td width="0" height="0"> <table width="100%" border="0" cellpadding="5" cellspacing="0"> <tbody><tr> <td class="midtext">Those are water cooled exhaust manifolds.
I'm planning to install the engine on a boat.</td></tr></tbody></table></td></tr></tr></tbody></table>
waldrop4
307
12-10-2023 07:13 AM
Liberty_911
08-09-2012 10:55 AM
Shwan_89HD
15
01-24-2012 09:43 PM
