Beat the Scrap Man to it!
SO I beat the Scrap man to a nice EAB flathead (car engine) (alum timing cover, stamped steel half bell, attached to a T-98 trans) it came out of what the owner said was a 1950 truck but he didn't know anything else about the truck and this was all that remained of the truck as it had already been hauled off to the scrapper. paid a little more than scrap price for it, so it was a win win.
Don't know if it runs but turns over just fine, will clean it up and see what she'll do.
Cheers
Josh
Cheers
Josh
Stamped steel bell-housing was from a Mercury, but works and is similiar in appearance to the cast iron truck housing.
Sometimes a pig in a poke turns out quite well. I was given an 8BA, actually a 1BA as was cast in the block, from a club member. He knew nothing about it. It had the 53 truck bell-housing and U-shaped front mount. I removed a head and saw nice clean bores and very lightly carboned pistons, no visible cracks. I then removed the intake and saw the lifter valley was almost clean enough to eat out of. The one problem I saw, which may be why it was pulled, is that one of the guide retainers had jiggled out. Not sure why, I haven't looked into it. Could have been installed incorrectly, or there could be a problem with that guide/valve. In any case, it is my belief from what I have seen on the top end, that this was a low mile rebuild.
Its more aerodynamic and boosts performance. By 0.001%
. Lol. Don't really think there's any difference in them other than you used to see them sell for around $75.
There are a couple different distributors and I think these alum covers have the distributor's end shaft that goes into a little pocket? Retainer? Not sure what ya call it? Ya just don't ussually see them. I had an 8ba a while back that had one as well.
Ross. I will have to look at the oil line routing again, I also have a merc 8cm but didn't nOtice the difference. Where do I look? Thanks
Josh
Josh
redman84
34
11-21-2011 04:40 PM
Gary Lewis
41
08-17-2011 08:55 PM
79outlawf150
08-04-2010 12:59 PM
