truck eating coolant
Old 10-25-2010, 08:48 PM
NjOffRoaderX's Avatar
NjOffRoaderX
NjOffRoaderX is offline
well it appears my truck is eating coolant. it will smoke like crazy and the engine will vibrate like crazy and my coolant reservoir depletes itself every week. im assuming one of the head gaskets is blown. any one have any suggestions?
Old 10-25-2010, 09:42 PM
Ultramagdan's Avatar
Ultramagdan
Ultramagdan is offline
Based on your mileage, you have a decision to make. Rebuild the motor, trade it off, or buy a rebuilt block and go from there. This is a big project you are looking at. It would be good to do a compression test of the cylinders to make sure but I think the writing is on the wall.
Old 10-25-2010, 10:08 PM
NjOffRoaderX
actually i found out one of my freeze plugs cracked.
Old 10-25-2010, 10:18 PM
Podaso's Avatar
Podaso
Podaso is offline
Lucky! Was it hard to get to to replace?
Old 10-25-2010, 10:28 PM
NjOffRoaderX
umm well im goiing to do an order on autozone tonight they have them for .99 a piece put its going to be a pain to get to.
Old 10-25-2010, 10:34 PM
Podaso's Avatar
Podaso
Podaso is offline
That's what I figured. Just looking at mine makes me think an all day project. Let us know how it goes replacing it.
Old 10-25-2010, 10:41 PM
NjOffRoaderX
will do. im also ordering the imrc runner clips. everything is just going at once -__-. once i get it running sound im going to over haul it i think
Old 10-26-2010, 06:41 AM
Ultramagdan
Ah! A freeze plug sure beats a blown head gasket. Glad it was something simple.
Old 10-26-2010, 06:55 AM
Joe Finn's Avatar
Joe Finn
Joe Finn is offline
What year truck and which engine? The freeze plug can cause you to lose coolant, but I don't get the connection between the freeze plug and the smoke. Is the smoke coming from the exhaust or from iunder the hood?
Old 10-26-2010, 01:51 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Freeze plug leaks directly on the exhaust manifold, the vibrating though I a not sure of.
Old 10-26-2010, 05:09 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
either the antifreeze is getting onto a COP and causing the missfire, or the head gasket still has a small leak, due to motor overheating due to the freeze plug leak.. Fix the freeze plug first, clean coils and wires, then test again... if you still have water usage, consider BARS head gasket sealer to fix that
Old 10-26-2010, 06:02 PM
NjOffRoaderX
ok heres an update. the freeze plug is making it loose coolant. and its burning oil actually. the smoke is coming from the exhaust. and on top of that the imrcs.....
Old 10-26-2010, 08:07 PM
NjOffRoaderX
another update! ive done research. white smoke and the horrible smell refer to burning coolant. so its not burning oil it has to be coolant
Old 10-27-2010, 09:07 PM
Ultramagdan
I would pressure check the system. Sounds like your motor has multiple issues.
Old 10-27-2010, 09:10 PM
NjOffRoaderX
well now i went to go start it and now its ceased up............. so im on a search to find a new motor. what could i fit in there without messing with the bolt degrees and be a decent fit.
Quick Reply: truck eating coolant
