ficm/ injectors
ficm/ injectors
i have a 2004 f-250 with 6.0 turbo. would bad batteries cause the ficm to mess up randomly. went it is hot, temp and truck i come to stop light and truck starts to feel like it misses. But this is random not all the time. my thought is the ficm is starting to go bad or dropping a injector which still goes back to ficm. what is your thoughts please. want it fixed before it gets cold please help.
brandon
brandon
Bad batteries if not addressed quickly can potentially destroy a FICM...
-Test the alternator
-If bad, replace
-Load test the batteries
-If bad replace
-You may end up replacing both, be prepared...
-Test FICM control module for 45-48 Volts using this procedure: https://www.ford-trucks.com/forums/8...procedure.html
-If bad, replace
-If bad replace
2006powerstroke90
10-16-2011 03:18 PM
