upper and lower ball joints on my 02 - Ford Truck Enthusiasts Forums
Old 10-25-2010, 01:57 PM
sand_fiend's Avatar
sand_fiend sand_fiend is offline
Work in Progress
sand_fiend has a very good reputation on FTE.sand_fiend has a very good reputation on FTE.sand_fiend has a very good reputation on FTE.
so i just spent the morning having tires put on getting ready for the alignment, only to have the shop tell me that my ball joints are bad. they said that for my 2002 f250 diesel it is normal for them to start going out around 100k...i have 124k on it now....shop wants to charge me 745 bucks and 4 hours worth of labor...here is my question...is this something that i can do at home....labor too intense or easy enough? should i get ford replacement parts or go after market? anybody else having these same issues or know what all is involved in the parts and the replacements? any advice would be appreciated....thanks
Old 10-25-2010, 02:16 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
It's real easy if you have the proper tools like a ball joint press, etc.
Impossible if you don't.
I bought Ford ball joints, they now have zerks for periodic lubrication service.
60RatRod's Avatar
60RatRod 60RatRod is offline
60RatRod has a good reputation on FTE.60RatRod has a good reputation on FTE.60RatRod has a good reputation on FTE.
I will be having mine done very soon. I understand its very labor intensive, 8 hours or more. The tools can be rented and made with the exeption of a press, which im sure you could have a local shop do. I am up in the air if I am going to attempt DIY or just have my local driveline guy do it. I have a Sterling w/ 4:10's laying around the garage but don't want to install it just yet because I have 3:73's (4X4) and have'nt found or want to spend the cash on front 4:10's. Maybee I will get lucky and find a front Dana 50/60 with 4:10's locally.
Old 10-25-2010, 03:06 PM
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
I did mine at home but I also had the use of a shop press at work. Mine is a RWD so it is a lot eaiser than a 4X4.
Old 10-25-2010, 03:10 PM
60RatRod's Avatar
Here is an outstanding link by another FTE member;
http://www.ford-trucks.com/forums/35...ll-joints.html
Old 10-25-2010, 03:19 PM
Deluxe06's Avatar
4000 rounds a min
Old 10-25-2010, 03:36 PM
milleroutdoors's Avatar
milleroutdoors milleroutdoors is offline
milleroutdoors has a very good reputation on FTE.milleroutdoors has a very good reputation on FTE.milleroutdoors has a very good reputation on FTE.milleroutdoors has a very good reputation on FTE.
I did mine in my shop, press is needed, or simple ball joint press. If 4x4 good time to do new seals in hubs grease spindle bearing and grease slide pins and anything else you can think of.
Old 10-25-2010, 03:54 PM
BrandonT71's Avatar
BrandonT71 BrandonT71 is offline
BrandonT71 is starting off with a positive reputation.
Had to do mine about a month ago after doing front brakes and and tie rods. When I took the truck into the alignment shop, they said they couldn't do the alignment 'cause the ball joints were shot. I'm no mechanical genius and I found the task well within my comfort zone. I would cation that if don't have a a pickle fork or a tie rod/ball joint seperator, your going to wish you did. Not sure about parts stores in your area, but Autozone had what I needed to rent, which turned out to be a deposit only. Upon returning the tool they credited back my account the rental fee! I used BAW ball joints from NAPA and both upper and lowers came with zirks. One note of cation here, the upper ball joints came with straight zirks, which once installed would be next to impossible to get a grease gun onto, so I changed them to 45* zirk fittings. As far as having the ball joints pressed in, I simply took my steering knuckles to a local mechanic's shop and they pressed them in for me and only charged me 1 hour of shop time. While you've got things apart, I would give your tie rods a close thorough inspection, as they are known to go bad as well. Good luck on doing the work yourself, you'll save yourself a pant load of money to boot!
Old 10-25-2010, 04:11 PM
60RatRod's Avatar
So those of you that did the work yourselves, how long did it take?
Old 10-25-2010, 04:26 PM
BrandonT71's Avatar
Did mine in a couple of evenings after work, a couple of hours to pull everything apart, take knuckles into shop and have ***** joints pressed, picked up later that day, and then a couple of hours to put everything back together. I did a bit of claening and touch up painting while things were apart, so I think I had about 6 hours total into the project.
Old 10-25-2010, 08:06 PM
Orezona's Avatar
Orezona Orezona is offline
Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.
Hope this link helps.http://www.ford-trucks.com/forums/35...ll-joints.html
The other link I used and posted in the past has been deleted by another site.
I rented/borrowed the tools from Advance Auto for FREE when I did mine. I gave them my CC number and returned the tools within the time period and didn't get charged a dime.
Old 10-25-2010, 09:09 PM
indyF-350psd's Avatar
indyF-350psd indyF-350psd is offline
you can't fix stupid!
indyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to beholdindyF-350psd is a splendid one to behold
i bought the moog ball joint kit from powerstrokeshop.com since its right down the road and took them and the truck to a local shop that builds world of outlaw transmissions and all kinds of cool stuff and they charged me 350 bucks to put the ball joints in and get an alignment. worth the 350 imo.......
Old 10-25-2010, 09:30 PM
camodown's Avatar
camodown camodown is offline
camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.
Quote:
The 45* zerk with get broken by your u joints. Install a straight zerk and use a 90* grease gun fitting, then you can leave the zerk in all the time!
Old 10-25-2010, 09:48 PM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
If you have confidence in your ability do it yourself, mine had just been done at 117,000 when I bought my truck but did a friends 4x4 dually. No issues and it should be done in 4 or less actual working hours. More time dependent on extra things you get into, e.g. cleaning, painting, greasing etc...
Good luck.
Old 10-25-2010, 09:59 PM
clem1226's Avatar
clem1226 clem1226 is offline
clem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to behold
Quote:
I put 45* zerk fittings in mine 2 years ago, once the snow fly's I leave the front hubs locked until Punxsutawney Phil gets dragged out of his hole and haven't broken one yet.
Some trucks they work and some they don't.
Front Drive Shaft Repair Tips 5.4L to Freedom 1999 to 2016 Super Duty 4 01-17-2011 08:13 AM
Labor cost for 2wd Ball Joints 2002 F350V10 1999 to 2016 Super Duty 9 03-11-2010 09:08 AM
Squeaky ball joints cbradford Excursion - King of SUVs 8 10-20-2008 07:46 PM
Ball Joint Replacement? Olds_442 Brakes, Steering, Suspension, Tires, & Wheels 1 07-10-2008 12:46 PM
Ball joint labor time rob5482 Excursion - King of SUVs 37 03-31-2006 05:14 PM
Tags
2002, 250, ball, change, duty, f250, ford, joint, joints, lower, photos, ranger, replacement, super, truck, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
