Block Heater
Your 2005 would not have come from factory with the cord but will have the connection for it. All 6.0s have the connector for the block heater in the above stated location but the cord only came stock in 2003 and 2004. After that they quit putting the cord on every truck. You can pick up the cord for around $19 shipped off ebay or around $60 from a dealer, and it will plug right in.
The cord The cord !!!!!!
Great found the cord Yep as said next to yee old tow hook as the installer at the Kentucky Plant had placed it never used all these Years still as new.The truck has been stored inside winters from new just 26,ooo miles and rust & salt free I have had it greese undercoated 2 times by 2 different shops She is a old Truck but also a nice ride 4x4 remote start 4 doors HID lights like new in all ways runs as new also I bought it off the Family of the owner that past away.Came with a 5wheel hitch and tailgate and the OEM tail gate pulls My 33' 5th wheel Cedar Creek just fine.Thanks for the help Guys great site and great helpfull folks also..Bush
Guys,
Remember that the block heater draws about 1100 watts, so try to use a 25ft (or shorter) 12/3-wire extension cord and plug it into a circuit that isn't too heavily loaded to keep from tripping your breaker.
I just bought an inline timer to allow the power to be turned on to the block heater about 2 hours before I leave in the morning - rather than having it plugged in all night.
Also here's a hint: I usually will run the cord up over my drivers side door mirror - to remind myself I have the block heater plugged in - because I don't want to start to drive away with the cord still plugged in...... yes, I've nearly done it myself! It's easy enough to do when you don't see/cross the cord before jumping in, or if the cord is covered by some overnight snowfall - trying to drive away with it still plugged is NOT GOOD for the plug ends!
Just my 2 cents,
BarnieTrk
Just my 2 cents,
BarnieTrk
Great idea with the timer.I use a 12/3 cord I think It is about 30 feet I made up some for the camper and wanted something better than the 14 or 16 gage. Didn'T know it was 1100 watts but I knew it was a lot the cord would melt the snow. Haven'T needed to use it the past 2 years I go to south Texas for the winter.
If it's there, it is near the passenger side tow hook. I had to look twice to find mine. But, first, look above your starter and see if it has one.
See here:
Diesel Technician Society
If it's not there, see the post you quoted for info on finding one.
See here:
