Block Heater - Ford Truck Enthusiasts Forums
Block Heater
Old 10-25-2010, 10:58 AM
Bushman512003 Bushman512003 is offline
Bushman512003 is starting off with a positive reputation.
Block Heater
New to Me F250 2005 PSD V8 do they have a block heater I can not find one but I would think it is some place But where is the cord?I am in Ontario Canada and think it will be cold soon lol But I do hope not...Thanks in advance Bush
Old 10-25-2010, 11:08 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Cord "SHOULD" come out near the front passenger tow hook. To make sure you DO have one, look up over the starter at the block and you should see it. It threads forward to the tow hook area.
Old 10-25-2010, 12:06 PM
Cowboy65's Avatar
Cowboy65 Cowboy65 is offline
Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.Cowboy65 has a very good reputation on FTE.
See the following link for more info on the block heater cord location:
Diesel Technician Society
Old 10-25-2010, 03:12 PM
rocky1074's Avatar
rocky1074 rocky1074 is offline
rocky1074 is gaining momentum as a positive member of FTE.rocky1074 is gaining momentum as a positive member of FTE.
As BPofMD stated it's behind the pass tow hook on the right side looking at the tow hook zip tied in the corner.
Old 10-25-2010, 04:19 PM
hubler13f's Avatar
hubler13f hubler13f is offline
hubler13f has a good reputation on FTE.hubler13f has a good reputation on FTE.
Your 2005 would not have come from factory with the cord but will have the connection for it. All 6.0s have the connector for the block heater in the above stated location but the cord only came stock in 2003 and 2004. After that they quit putting the cord on every truck. You can pick up the cord for around $19 shipped off ebay or around $60 from a dealer, and it will plug right in.
Old 10-25-2010, 04:36 PM
BPofMD's Avatar
Posting Legend
Quote:
Oh contrair my friend. If he's in Canada, it WOULD have come with the cord!
Old 10-25-2010, 04:42 PM
hubler13f's Avatar
Quote:
OK maybe I'm wrong then.
Old 10-25-2010, 06:12 PM
The cord The cord !!!!!!
Great found the cord Yep as said next to yee old tow hook as the installer at the Kentucky Plant had placed it never used all these Years still as new.The truck has been stored inside winters from new just 26,ooo miles and rust & salt free I have had it greese undercoated 2 times by 2 different shops She is a old Truck but also a nice ride 4x4 remote start 4 doors HID lights like new in all ways runs as new also I bought it off the Family of the owner that past away.Came with a 5wheel hitch and tailgate and the OEM tail gate pulls My 33' 5th wheel Cedar Creek just fine.Thanks for the help Guys great site and great helpfull folks also..Bush
Old 10-25-2010, 06:21 PM
rocky1074's Avatar
Quote:
I knew you would find it if you looked hard enough. They hide it real good..I didn't know I had one for the first 4 years I owned the truck..lol
Old 10-26-2010, 07:26 PM
claytonc claytonc is offline
claytonc is starting off with a positive reputation.
Glad you found it. some of the 2005 depending what state you are in didn't come with the cord,Michigan was one of the states they said didn't need one, two years ago on my way to work my truck said 16 below it was moaning and groaning after that I put a cord on.
Old 10-27-2010, 04:46 AM
Block Heater
Thats funny Mich.State was left out for the cords I am in Ontario across from Alginac Mich.and We get the same cold as You what part are You in ?The wife is from Pt.Huron .We know a lot of people in the North also We camp up State. Bush
Old 10-27-2010, 08:25 AM
BarnieTrk BarnieTrk is offline
BarnieTrk is gaining momentum as a positive member of FTE.BarnieTrk is gaining momentum as a positive member of FTE.
Guys,
Remember that the block heater draws about 1100 watts, so try to use a 25ft (or shorter) 12/3-wire extension cord and plug it into a circuit that isn't too heavily loaded to keep from tripping your breaker.
I just bought an inline timer to allow the power to be turned on to the block heater about 2 hours before I leave in the morning - rather than having it plugged in all night.
Also here's a hint: I usually will run the cord up over my drivers side door mirror - to remind myself I have the block heater plugged in - because I don't want to start to drive away with the cord still plugged in...... yes, I've nearly done it myself! It's easy enough to do when you don't see/cross the cord before jumping in, or if the cord is covered by some overnight snowfall - trying to drive away with it still plugged is NOT GOOD for the plug ends!
Just my 2 cents,
BarnieTrk
Old 10-27-2010, 04:58 PM
Great idea with the timer.I use a 12/3 cord I think It is about 30 feet I made up some for the camper and wanted something better than the 14 or 16 gage. Didn'T know it was 1100 watts but I knew it was a lot the cord would melt the snow. Haven'T needed to use it the past 2 years I go to south Texas for the winter.
Old 10-27-2010, 08:48 PM
superdutyon37s superdutyon37s is offline
superdutyon37s is starting off with a positive reputation.
I just purchased an 06 250 harley edition. Looked for the cord havent found it...Any specific place i should look??
Old 10-27-2010, 08:51 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
If it's there, it is near the passenger side tow hook. I had to look twice to find mine. But, first, look above your starter and see if it has one.
See here:
If it's not there, see the post you quoted for info on finding one.
Freeze Plug or block heater? idiabuse Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 11-29-2014 01:26 PM
Help with after market Engine block heaters please blueeyedfordguy General Diesel Discussion 9 12-16-2013 02:22 PM
Instructions on installing block heater on 6.7L golfmedik 6.7L Power Stroke Diesel 1 11-16-2013 05:09 AM
Replacing block heater ?? maevans 1999 - 2003 7.3L Power Stroke Diesel 10 01-01-2009 11:56 AM
Block Heater automaticj5 2004 - 2008 F150 11 11-17-2006 09:27 PM
Tags
05, 2005, 350, 60, 60l, block, cable, connection, didnt, ford, heater, heaters, liters, powerstroke, psd, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
