1994 transmission fluid change - Ford Truck Enthusiasts Forums
Old 10-25-2010, 08:32 AM
tk1251k tk1251k is offline
tk1251k is starting off with a positive reputation.
Just did a filter and fluid change on transmission. It was 1 qurart over before I drained the pan and removed the filter.I drained alittle over 4 quarts maybe 41/2 out. I added back 4 quarts and have drive for 2 days now and its still a quart low or up on the stick about 1/4 inch. I cannot figure what happened to 2 quarts.I checked a few times before changing fluid too make sure it was reading 1 quart over which it definitely was.Could air have been causing a faulty reading. I have had trouble with tranny going into drive recently but wouldnt think that would be caused by overfill reading. Any ideas.
Old 10-25-2010, 07:14 PM
V8Ranger302's Avatar
V8Ranger302 V8Ranger302 is offline
V8Ranger302 is starting off with a positive reputation.
Check the fluid while its hot. If its between the low low and full marks ( in the cross hatching area) then its not that low. If its between those two marks its only low about a half a pint or 1/4 quart or so. Usually when doing a trans service on those they will take about 5 quarts.
4R100 Transmission- 10 quarts??? Suggestions? ExPACamper 1999 - 2003 7.3L Power Stroke Diesel 10 12-15-2015 11:05 PM
Another transmission fluid capacity? Gatordog 1999 - 2003 7.3L Power Stroke Diesel 3 10-11-2015 10:35 PM
06 Navigator 6 speed ZF Automatic Transmission Fluid Change Procedures max3860 1997-2006 Expedition & Navigator 2 09-08-2015 10:49 PM
Transmission (automatic) fluid & filter 5/23/2015 dn29626 1999 - 2003 7.3L Power Stroke Diesel 6 05-24-2015 05:59 AM
Please Help what is the correct fluid amount desertstorm-007 Aerostar 7 09-22-2003 01:55 AM
Tags
1994, 30, 94, bronco, change, explorer, fliud, fluid, ford, oil, recommended, tranny, trans, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
