Auxillary Transmission Cooler - Ford Truck Enthusiasts Forums
Old 10-25-2010, 08:52 AM
ducktang ducktang is offline
ducktang is starting off with a positive reputation.
I have searched the threads and need a couple of questions answered:
It looks like the aux cooler needs to be in line after it comes out of the radiator. I also read that if you mount it to the a/c condenser with those zip ties, it heats up the fluid more than it is cooled. If you don't mount it to the condenser, you won't get much help when idling or moving slow, pulling air over the cooler with the engine fan. So, those of you with them mounted, what works best for you? I'd like to mount one close enough to the condenser to let the engine fan help. Should I mount it directly next to it or stand it off with some spacers maybe an inch or so? Thoughts?
Old 10-25-2010, 02:07 PM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
The factory cooler on my 94 F250 is mounted on a vertical strut at the front of the engine bay. It is in front of all the coolers and is about 4 inches ahead of them. It gets air from road speed or air pulled thru the grille by the fan
All the aftermarket coolers I have installed(3 or 4) were mounted in front of all the other coolers and usually had some sort of spacer/cushion to allow maybe an inch at best of air gap between the tranny cooler and all the rest.
Hope that helps some.
Jim Henderson
Old 10-25-2010, 03:27 PM
What would you use for a spacer? Small wood blocks?
Old 10-25-2010, 09:49 PM
rclarke rclarke is offline
rclarke is gaining momentum as a positive member of FTE.
Any non-heat conducting material will work. I used to pull the grill on some models and mount the cooler on the back of the grill with fabricated brackets. Makes several inches of clearance.
Old 10-26-2010, 09:07 AM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
Quote:
No.
Wood or any hard material will result in either the rad or cooler having a hole rubbed through.
Use a softer material.
Or tie it off with some form of strap away from the rad or condensor.
Old 10-26-2010, 01:26 PM
I am going to try some of the semi-hard black high density foam insulation that you get at the hardware store to wrap your water pipes and see how that works.
Old 10-26-2010, 01:56 PM
Yeah, that is what came with the kits I have installed. The foam blocks were maybe 1.5x1x1 and had sticky stuff on them to hold them in place while you mounted the cooler with zip ties or some other plastic hold downs.
The foam has to be stiff enough to keep from compressing but soft enough to not damage the fins of the coolers.
I always worried that the foam or plastic ties would wear out due to heat and vibration. BUt, I never had a problem and sold those vehicles with many miles and years on them.
Good Luck,
Jim Henderson
Please help me with my custom A/C sittinlow88 1967 - 1972 F-100 & Larger F-Series Trucks 3 04-05-2015 11:41 PM
Inexpensive E4OD Tranny Cooler Hamberger Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 08-05-2014 01:01 PM
2007 E450 6.0 PSD AC Condenser Replacement Chauncey237 Cooling, Heating, Ventilation & A/C 2 09-04-2013 06:23 AM
2007 E 450 6.0 PSD condenser replacement Chauncey237 1968-2013 Full Size Vans 1 07-19-2013 07:14 AM
Where should auxillary tranny cooler be mounted? mrad Excursion - King of SUVs 40 08-19-2010 05:16 PM
Tags
aux, cooler, coolers, engine, fan, ford, plastic, raptor, semi, ties, trans, transmission, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
