Pulled the cab.. ARP Head Studs and Black Onyx Head Gaskets 500 pictures!!!
Old 10-24-2010, 07:03 PM
1_BIGMOFO's Avatar
1_BIGMOFO
1_BIGMOFO is offline
First off I would like ot thank Pete at Greenwood Contracting. Pete was kind enough to help me do this job in addition to dealing with me being **** the whole time....
We cleaned everything, painted everything including the frame.. POR15'd any rusty spots prior to paint! Painted my turbo pipes and everything went great. We took the heads, rocker boxes, and manifolds to XLR8 Machine shop and Steve Stack did a KILLER job on my heads!! He bead blasted the manifolds and made everything SUPER nice! I also want to thank Adam at FCDP for the hookup on the parts!!
Pete and I rebuilt the oil cooler when we did the EGR delete less than 6 months ago so we didnt do it again.
As you can see from my pictures, NO EXPENSE WAS SPARED!!!!! I purchased everyhting I could new rom Ford (right from the dealer) and / or aftermarket if something was available..
Please see the 500 pictures. I think they are self explanitory! I am open to any feedback or questions anyone may have!! The truck is SWEET and I plan to keep it forever. Its been 3 years and its been good to me. Once its paid off im planning on a turbo and injector upgrade..
bye bye head bolts!!!
thank you to Steve Stack at XLR8
heads
stripped frame!!
Studs
gaskets
primering up the turbo piping
make sure you oil EVERYTHING:
and keep EVERYTHING in order
fresh paint
F250 Head Gaskets and Studs October 2010 pictures by RobertFendrick - Photobucket
Old 10-24-2010, 07:07 PM
1_BIGMOFO's Avatar
1_BIGMOFO
well, you get the point... Check the photobucket link to see almost 500 pictures. if you have any questions please ask!!
Old 10-24-2010, 07:10 PM
1_BIGMOFO's Avatar
1_BIGMOFO
Old 10-24-2010, 08:53 PM
cheezit's Avatar
cheezit
cheezit is offline
great pic. nice to see it all worked out. only thing I see is that is a negitive is the non oem air filter. the oem unit is by far the best unit on the market.
Old 10-24-2010, 08:56 PM
cheezit's Avatar
cheezit
cheezit is offline
also I can tell if you still have an egr valve. if you removed it varify your fan still works.
Old 10-24-2010, 09:11 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
hey cheezit, I have mine deleted completely, cooler and all in an 03 truck, if I just put a dummy valve in there do you think it will be enough to have the computer run the fan?
Old 10-24-2010, 09:12 PM
cheezit's Avatar
cheezit
cheezit is offline
dont know only one way to check. get out a scan tool and command fanvar# and watch vanss and rpm pids.
Old 10-24-2010, 09:13 PM
rollerstud98
alrighty, thanks!
Old 10-24-2010, 09:19 PM
High Binder's Avatar
High Binder
High Binder is offline
Cool! I love the plate by the way, gotta **** off the hippies!
Old 10-24-2010, 09:53 PM
vlietracer64's Avatar
vlietracer64
vlietracer64 is offline
Whats the correlation between the fan and the egr valve, thought the fan was commanded to come on based on multiple sensors and reading
Old 10-25-2010, 11:07 AM
desertt5's Avatar
desertt5
desertt5 is offline
I deleted my EGR in my 03. According to AE it did not mess with the fan.
Old 10-25-2010, 05:54 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
1_BIGMOFO, I must say, you really do now your truck now! This is the second set of pics you've done, and I really appreciate what you have provided here. Thanks for sharing!
Reps for your efforts!
Old 10-25-2010, 06:50 PM
cheezit's Avatar
cheezit
cheezit is offline
simple enugh trace ckt 361. It seems to have soemthing do with this and pcm calibrations.
Old 10-25-2010, 07:51 PM
AndeyHall's Avatar
AndeyHall
AndeyHall is offline
Save the link to favorites...definitely comes in handy when you need a broken down picture of the engine. Thanks man.
But I too have wondered about the whole EGR delete thing. What exactly is a dummy valve? I did a complete EGR delete except my valve is still there? What does that mean? Don't mean to hijack...just figured this might be some of the same info others need also.
Old 10-25-2010, 08:17 PM
Stewey's Avatar
Stewey
Stewey is offline
Great job. What kind of prep was needed for the POR-15.
Quick Reply: Pulled the cab.. ARP Head Studs and Black Onyx Head Gaskets 500 pictures!!!
