7.3 diesel coolant flush
Is it enough to just flush out the radiator or should I do a complete radiator/engine coolant flush on a 2005 F250 with 180k miles. Also, what to use, regular antifreeze, 50/50 anti freeze or concentrated antifreeze. I read about all different ways. Which is the best way.
Welcome to FTE. A complete flush is the way to go using distilled water. If you do it yourself, you'll have a hard time getting all the distilled water out, so I'd go with the concentrate where you can check the concentration and adjust later.
The 2005 didn't come with a 7.3 diesel unless you bought it with the steering wheel on the wrong side Your profile says you're in Florida. Are you sure you don't have a 6.0? Don't buy the green coolant for a 6.0.
Haroon
1997-2006 Expedition & Navigator
12-16-2010 08:58 PM
Brownbear13
1997 - 2003 F150
04-02-2008 09:54 PM
