88 ford f250hd 351 5 speed 4x4 what to expect
just picked up this truck couple weeks ago, tthe truck will be drove daily and ocasionally use to haul up to 10k lbs. on a trailer. my question is "what are the first things to break or mess up?" i am a backyard mechanic so i will be doing all the work my self.
also i might have access to all the leaf springs (only) off a 91 f30 4x4. any disadvantages to swapping those to my truck?
thanks
thanks
on
That's a tough truck so there's isn't much that will break. The F250HD was essentially an F350 anyway with a full floating 10.25 rear axle and bigger leaf stacks so you may not see any gain from the F350 parts. Typical wear items are brakes and U joints, and the 4x4 shifters always seize up and will break the linkage if you force them, disassemble and libricate it instead.
What you should also know is the truck is way underpowered as delivered, there is a lot of potential under the hood but Ford smothered these early motors badly with a tiny cam and restrictive exhaust. These two issues can be addressed fairly cheaply but you could also just live with it, you just won't be getting anywhere very fast with 10k strapped on behind.
well after i do the clutch kit, flywheel and slave cylinder, the brakes are next. the ebrake barely holds on flat ground. i crawled under and saw it was only pulling from the passanger side. drivers side is either rusted or stuck.
from my mustang expirence, i will go with long tubes for that low end, and cam wise i am a little up in the air. Lunati 90351LK - Lunati Truck Avenger Cam and Lifter Kits this is one kit i have looked at. i will definitly do alot of research before that purchase. my top speed will be 45 mph when towing , so every bit of low end power i can get i will take. any other secrets or opinios on that would be helpful
Sterling is the best diff they came out with in an Fseries light duty pickup until the superduty's made the Dana 80 available.
They are stout, and with a windsor you'd have to be trying REALLY HARD or being REALLY STUPID to break one.
they only forseeable issue you could possibly have is needing to tighten up your yoke on the diff. Thats usually on really high mileage units, or trucks that have done a fair amount of towing.
from the id palte on the front axle, i believe it is the dana 50. also cause mine is a HD (if i am correct) it means i have a dana 50.
lets just say i did something stupid and broke the rear end (i didnt) where woulds i get parts for it? how about getting a rear axle out of a late 90's f250
That is such a load of crap. All the companies say that and I have yet to have 1 problem pulling long tubes on a D60 truck
Which ones fit, according to the companies, the only one that says they will fit is flowtech 12504 for the 351w. I'd like to know which ones will fit, because i'd like to put long tubes on my 1990 f350, but i don't want to buy something that i can't make fit. and i'd like to have something with primaries bigger then 1.5"
