88 ford f250hd 351 5 speed 4x4 what to expect
on
Why... it's not like the motor needs anything bigger.
from the id palte on the front axle, i believe it is the dana 50. also cause mine is a HD (if i am correct) it means i have a dana 50.
lets just say i did something stupid and broke the rear end (i didnt) where woulds i get parts for it? how about getting a rear axle out of a late 90's f250
Depends on what you break. There are plenty of online stores that will sell you about anything you could possibly need to fix them. Alot of times especially here in the Midwest it's easier to buy another 10.25 for $200-$300 and swap axles rather than buy the parts and fix the origional.
You can't really get much better than full float sterling axles... Well let me take that back... You might want to look into a detroit locker. The open diffs on the sterlings suck if you go off road at all.
As far as long tube headers I have heard that Pacesetters have the best fit but I have hedmans myself...
I have the Flowtechs and they suck, they fit on the truck and motor no problem but they hang too low and the collectors end up right in front of the trans crossmember so connecting the rest of the exhaust is a royal pain.
Because I have a set of mildly worked 1970 351 windsor heads (D0OE) to go on the motor. The Valve sizes have been enlarged to 1.96 intake and 1.60 on the exhaust side. I would like to find a set of 1 5/8" primary tube headers, because this would fit the exhaust valve better then a 1.5" diameter header tube. In this case the 1.5" headers would choke it a little bit.
on
Upgraded heads will help but with the stock cam in that motor it'll still be well short of requiring bigger headers. And even if you did upgrade the cam(Crane 444232 with 1.7 rockers HIGHLY recommended) the slightly smaller headers will produce more TQ through the low end and mid range.. which is what you really need in a truck.
Sterling is the best diff they came out with in an Fseries light duty pickup until the superduty's made the Dana 80 available.
They are stout, and with a windsor you'd have to be trying REALLY HARD or being REALLY STUPID to break one.
they only forseeable issue you could possibly have is needing to tighten up your yoke on the diff. Thats usually on really high mileage units, or trucks that have done a fair amount of towing.
I agree, one major problem w/ these axles is that the pinion nut that holds the yoke on likes to come loose. Easily fixed w/ a new nut, if you catch it soon enough, and know what your doing. JUST DONT OVERTIGHTEN IT!!!!!
Amphihauler
06-23-2016 01:46 PM
phoneman91
07-27-2015 07:53 PM
mikemoshier420
19
01-17-2009 10:18 PM
