Flat 6 water pump
Flat 6 water pump
After searching for a while I am sarting to think that rebuilding my water pump myself may be a poor idea. I have not been able to find any seal dimensions on line to match up my water pump. I wonder if anyone has measured the Ford 9N tractor rebuild kit to see if it will fit the 226 flat six pump body. I know that many manufactors kept the parts count down by useing the same parts every where they could. The 9N unit looks identical to the 226 pump. I have re machined the impeller for the seal seat. I know I could lap the existing seal and get good enough results. I plan on running the engine in the truck once in a while while I build up the "correct" driveline parts.
Marty
Marty
I also have a water pump, but I do not remember any details about it, If you are interested email me at fifty-two_f1@ndwave.com
I will be taking the parts and a caliper to the farm supply store today to measure a few things and will post the results. I am only interested in getting the engine running for a short while and am reluctant (read "really too cheap") to start rebuilding everything as I have several versions of race prepped V8's ready to install. The smallest motor is a 347 inch SBF-HO @435 flywheel HP. I plan on putting the flat 6 on a stand to run for the fun of it.
Marauder2004
06-30-2014 07:17 PM
two stars
02-25-2006 06:14 PM
