Diesel antifreeze - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Diesel antifreeze
Old 10-23-2010, 05:41 PM
ihuntalot ihuntalot is offline
ihuntalot is starting off with a positive reputation.
Diesel antifreeze
I have a 2002 F-250, 7.3 power stroke, when I bought it it had gold or yellow antigreeze and recently I have it flushed and new antifreeze installed but they put green antifreeze and they said it was the right application for my truck. What is the differance in gold or yellow and green additive, and why the change. Thank You
Old 10-23-2010, 05:48 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
"They" screwed up, and put the wrong stuff in.
Different chemistry.
Who are "they"?
Pop
Old 10-23-2010, 06:04 PM
They are a Ford Dealership
Old 10-23-2010, 07:13 PM
brwolfjr brwolfjr is offline
brwolfjr is starting off with a positive reputation.
my '02 came with gold. it is my understanding that they do not mix. Also, the green is a lot cheaper.
Old 10-23-2010, 07:54 PM
spdmpo's Avatar
spdmpo spdmpo is offline
spdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to beholdspdmpo is a splendid one to behold
You can mix them, but then you have to treat it like green. huntalot that's too bad a dealership did that to you, but your truck should have the gold antifreeze. Now you have to convince them to thoroughly flush it out with distilled water and get all the green coolant out and replace it with the gold. But a better option would be to get your money back and DIY and swap to a long life 'red' coolant.
Old 10-23-2010, 08:35 PM
Care to tell us in what city "they" are located?
Pop
Old 10-24-2010, 12:36 AM
diesel antifreeze
Selah, Wa is the town that this happened sorry to say
Old 10-24-2010, 07:38 PM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
+1 on changing to long life RED coolant.
Old 10-24-2010, 08:17 PM
Duzitall's Avatar
Duzitall Duzitall is offline
Duzitall is starting off with a positive reputation.
Just flushed my 2002 today with distilled water (and flushed me with other distilled stuff )
then put in Zerex non-diluted HD ELC that's CAT, Cummins and International rated purchased at Napa.
Hunter, you can keep the green stuff in there but you should add some SCA's like Napa Cool. Then you have to check the SCA level periodically. The Dealer screwed you by putting that stuff in there...just like mine did to me
Old 10-26-2010, 01:06 AM
bit breaker's Avatar
bit breaker bit breaker is offline
bit breaker is starting off with a positive reputation.
i just had mine flushed and replaced at jiffy lube during an oil change. the manager claimed his antifreeze was diesel rated and did not require sca's, does everyone agree or have a comment about them?
Old 10-26-2010, 02:17 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
The difference is found delineated in this thread. Scroll down to post number 4.
http://www.ford-trucks.com/forums/960812-goochs-radiator-engine-backflush-procedure-and-coolant-information.html#post8935201
Quote:
It depends on what kind of coolant he put in your rig. Color is not a precise indicator so you need to go back and ask exactly what brand was used and what requirement level it meets.
In my above thread, you'll see the differences between the three main coolants used in our rigs.
Stewart
Old 10-26-2010, 09:21 AM
kccatpower's Avatar
kccatpower kccatpower is offline
kccatpower is starting off with a positive reputation.
very good info, what method would you recommend for testing sca?
Old 10-26-2010, 10:51 AM
Duzitall's Avatar
Quote:
You can get test strips from Ford, Napa or any heavy equipment supplier like International. I never tested mine. I would just add more Napa Kool every couple years.
Old 05-31-2015, 03:53 AM
gn 609 gn 609 is offline
gn 609 is starting off with a positive reputation.
Pre September 1999 7.3 liter Coolant Issues
I have a 1999 F 350 off the assembly line in September 1998. I want to flush the system, and add new coolant. I did see the step by step blog, and understood it . I know I should be using a pre charged coolant, and have purchase 5 gallons of Fleet Charged SCA pre charged.
My question is may I use Zerez Extreme Duty Red from Napa, and avoid all the testing as I would have to do with the Fleet Charge by Peak.
Old 05-31-2015, 06:20 AM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
Antifreeze suggestions viper29 6.0L Power Stroke Diesel 12 10-09-2015 04:16 PM
Gold Antifreeze where to buy? perryg114 Excursion - King of SUVs 5 05-23-2014 04:07 PM
GOLD v. GREEN ANTIFREEZE - 7.3L PSD photomac 1999 - 2003 7.3L Power Stroke Diesel 7 11-21-2007 03:15 PM
Green or Orange antifreeze? biggreentank 1987 - 1996 F150 & Larger F-Series Trucks 19 10-10-2006 07:31 PM
Changing antifreeze on E450 ran Modular V10 (6.8l) 0 07-23-2004 09:23 PM
Tags
2000, 60, 73, 73l, antifreeze, deisel, diesel, f250, f350, fluid, ford, oil, powerstroke, radiator, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
