Hey guys - Ford Truck Enthusiasts Forums
Ohio Chapter Join Chapter, Leader: RUNVS
Hey guys
Old 10-23-2010, 03:08 PM
xWICkEdx xWICkEdx is offline
xWICkEdx is starting off with a positive reputation.
Hey guys
I am not the most active member on here. Just wanted to say hi and show off my new 89 bronco with a 5.8 in it. there is alot wrong with it
I am not a mechanic by far. But ok with a wrench. I just flushed the Radiator and checked the oil I found out yesterday that Auto zone and Advances does not run the codes any more for OBD I. So I bought a code scanner off ebay. the temp gauge and the oil presser gauge dont work got to find a way to fix them. standard ford rust. it needs new floor pans. Some hillbilly patched some holes with bush cans frame is good. Brakes look good on the front I have not seen the back. but every time I hit the brake pedal it fells like my truck has a heart beat on my foot. check engine light comes on when I am driving. I think it is because it needs a new thermostat IDK. But have big dreams for this truck.
Old 10-27-2010, 01:01 PM
sowder's Avatar
sowder sowder is offline
sowder is starting off with a positive reputation.
Looks like a good start, Just a few bugs to work out, on the gauge problem mine was where the wires plug together over by the brake booster before they go through the firewall (mines a 79), they was all green and broke into ( was a &^%#* to find). if its not just sending units. any way good luck just thought I would share that, maybe save you a little time.
Old 10-30-2010, 11:34 AM
It is not the sending unit I just replaced that i will look in the wire thanks
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
