Oil line leak, and hello lol
Hello, I recently traded for a 94.5 F350 with 7.3 turbo/5spd crewcab dually. Its got about 300,000 thousand miles on it. Im sure ill be askin lots of questions. lol.
Last night it wouldnt start before i left for work so I took my old dodge. This morning I got up and looked at as i was walking to my jeep and noticed a big puddle underneath it. So its oil. My friend came over with his flashlight and i cranked the engine and it turns out to be the steel braided line is leaking the goes from the passenger side valve cover(injectors?) to the fuel pressure regulator next to the filter. I guess its the fuel pressure regulator? lol So im gonna remove it have one made I guess. Anything special I need to know about that?
The truck needs some work buts its very rust free. And very comfortable.
that line needs to be able to handle 4000psi, that should do it! these engines use high pressure oil to fire the injectors, when you get the line made, it might be a pig to get it started again because of air in the head and will take a few miles to purge all the air out of the head so you may or may not see hard starts for a day or too. good luck!
If it goes to the FPR its a fuel line, if it goes to the HPOP is oil high pressure line, am I right?
on
Does this line go to the front of the heads behind the A/C and Alternator or does the line go to the middle/top of the head?
If it goes to the middle top its a high pressure oil line and you need to buy one from Ford. If its the smaller line that goes to the front of the heads its a fuel line and you could have one made as its only running about 60-70 psi
It goes to the center of the head. Definately oil as there is about 2 quarts under the truck in my driveway lol. I was gonna have one made up but im gonna call ford first. Anybody buy one yet and know what they go for? I havent had time to call yet. I will on mon.
What kind of kind of Maintenance is required to keep this engine happy?
