Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 10-21-2010, 09:53 PM
irwnn irwnn is offline
Garage is empty, add now
irwnn is starting off with a positive reputation.
61 Unibody Clutch
I've been digging around here with the search tool and on the net at the various vendors, but haven't found what I'm looking for so...
My truck is a '61 F-250 (VIN: F25JK170***)with an I-6 (C3AE-6015 AC cast on the side) and a four speed T-98. It's been an occasional driver/stuff getter/trailer puller with a slipping clutch for a few years and I figured it was high time I addressed the clutch. I just needed to get it back up and running since this truck will likely get a whole new drive train before it goes through another clutch.
After doing some research, I went with the Rock Auto "BRUTE POWER / PERFECTION CLUTCH Part # 92652" kit offering. I hadn't taken mine apart yet when I ordered the kit, but figured it was an 11" unit and went with it. I went in expecting to replace the pilot bearing,
release bearing, pressure plate, and friction disc and resurface the flywheel...
Then, I pulled my clutch apart yesterday...
The release bearing was so bad that it destroyed the release lever, release bearing hub, and the pressure plate drive lug fingers. I also discovered that the release lever retracting spring was missing. So it's back to the drawing board to find the release lever, release bearing hub, and the release lever retracting spring.
To add insult to injury, the inner "spline area" of the replacement friction plate is about 0.31" deeper than on the one I took off. I'm hoping it doesn't matter.
The only part I've found so far is a
release bearing/bearing hub assembly from Rock Auto. I already have a bearing as part of the kit I purchased, so another bearing would be a little wasteful. Any advice on where to find the release lever, release bearing hub (by itself), and the release lever retracting spring would be appreciated.
Thanks,
P
  #2 (permalink)
Old 10-22-2010, 04:56 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
B8C7515A .. Clutch Release Lever (aka Clutch Fork) / Obsolete
Fits: 1957/64 F100/950.
GOODE MOTOR CO. in Burley ID has 1 = 800-535-7278.
BARRY MOTOR CO. in Danbury IA has 1 = 712-883-2421.
JONES WEST FORD in Reno NV has 7 = 800-323-2223.
GREEN SALES CO. in Cincinnati OH has 29 = 800-543-4959.
B3TZ7561A .. T/O Bearing Hub / Obsolete
Fits: 1953/63 F100/700 / 1964 F100/350.
ARTESIA FORD in Artesia NM has 1 = 575-746-3578.
PIONEER FORD in Groton SD has 1 = 605-397-2311.
GRIESEL MOTOR CO in Okarche OK has 2 = 405-263-7242.
GREEN SALES CO. has 3.
KINSEL L/M in Beaumont TX has 6 = 800-816-2894.
C1TT7523E .. Clutch Release Spring / Obsolete
Fits: 1961/65 F100/250 2WD / 1966 F100/250 2WD before serial number 830,001.
GREEN SALES CO. has 8.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 10-22-2010, 05:00 PM
Very helpful. I'll print your post and start calling salvage yards.
Thank you.
p
  #4 (permalink)
Old 10-22-2010, 05:10 PM
Ford Parts Guru
2013 Ford Escape
Quote:
Look at the post again, there is no need to call salvage yards. I wanted to see where you lived before editing in the sources.
This is why I typed brb (be right back), watch this post.
Call around for the best prices. The dealers are usually cheaper than obsolete parts vendor Green Sales Co., cuz they are STUCK with the parts.
__________________
  #5 (permalink)
Old 10-22-2010, 05:21 PM
I thought brb meant "Bill's really Brilliant"
Just thought I'd get a head start in case stuff wasn't available. Again, thank you.
p
I'm in Phoenix, BTW
  #6 (permalink)
Old 10-22-2010, 05:27 PM
Ford Parts Guru
2013 Ford Escape
FYI: Don Sanderson Ford in Glendale AZ has tons of obsolete parts, but has none of these parts.
__________________
  #7 (permalink)
Old 10-22-2010, 05:33 PM
Sanderson Ford
Quote:
Good to know. Depending on the route taken, they are only 12-15 miles from my house.
p
Tags
1962, 1963, adjustment, clutch, f100, ford, rockauto, unibody
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
