Performance upgrade questions
Ok I have ordered my clutch, and have already pulled all needed parts from my parts truck, so now I sit here and wonder what performance parts Ii should order and install.
I use the truck for towing, its a 1997 4X4 ext cab and is in the middle of a 5 speed swap, it has 4.10 gears. so i guess my questions are,
What chip? i want a adjustable
Downpipe? I am putting stacks on as well, its a flatbed I think they look good with stacks
Gauges of course
turbo housing? yay, nay? or upgrade whole turbo? late model turbo conversion? those may happen later on down the road, unless you think a turbo housing will be good enough, only cause of money
and injectors will have to come later.
I have already done the DIY intake, but other than that its all stock
Gauges of course
For now do the exhaust system. Tymar makes some nice downpipes for our trucks so look into those.
Guages, ISSPRO EV2's or Autometer guages. Obviously you have a manual trans and only need a boost and pyro. Clay at Riff Raff Diesel has both of these brand guages.
turbo- leave it stock. Depending on how big of injectors you get down the road you will want the stock housing on the turbo or if you want more than stage 1 or 2's then you may be getting a bigger turbo...
6 position chip- www.totaldieselperformance.com (a chip from here would be Tony Wildman tuning which is what I run), Gearhead Automotive (this would be Matt's tuning), Diesel tuning products for Ford PowerStroke (Jody's tunes), etc. There are a lot of custom tuners out there for these trucks. you just have to decide which one you want.
HPOP- stock is fine for now, but when you upgrade the injectors later on, you will need a bigger HPOP. For stage 1's, 2's, or even small hybrids a modded 17* from Terminator Engineering would be great.
fuel system- You can shim the FPR with a BB for right now to keep your fuel pressure where it needs to be, but if your planning to upgrade injectors later on then you might want to look into an electric fuel system sometime in the future. Electric fuel systems are much nicer on these trucks than the mechanical pump and huge fuel bowl in the valley.
the 120v IDM is a stock super duty IDM(99-03). It is obviously more voltage than our stock IDM is and will get you a tad better throttle response.
The CCV mod is just to keep oil off the boots and making them easier to blow off. Just flip the doghouse around 180*, attach a hose to the 90, run it up over the brake booster then down under the truck making sure there are no kinks. You can vent that to atmosphere or run it through a catch can. I run mine to atmosphere about half way to the back of the truck..
120v IDM, 3 inch down pipe into the stock exhaust with the CAT and Muffler removed, BB mod to bump fuel pressure, 10k mod and a 46637 wix filter.
120vIDM I was happy with, felt I got a little more then the 10k mod, I removed all the mods one day and the truck felt like a slug.
I can see reading so much stuff at one time that it overloads your mind and it all just scrambles together. Did that with my F-150!! LOL. No worries. We are here to answer whatever questions you might have.
Just make sure you have guages before you get a chip on the truck. Modifying the fueling characteristics will raise the EGTs and obviously we want to keep an eye on that. Get you a good downpipe and 4" exhaust to get that out of the way.
The stock HPOP is fine until you decide to upgrade injectors. At that point you will need to get a better HPOP.
The stock turbo is good for up to stage 2 injectors. Stage 2's will kill the stock turbo over time depending on how heavy your foot is.
The stock fuel system will handle stage 2 injectors, but an electric fuel system is always a nice upgrade.
An intercooler will help also to lower EGTs and may give you a couple horsepower also.
Just stick with us, we are here for when you get a little confused. We will have you melting tires in no time!
