Electrical problems - Ford Truck Enthusiasts Forums
Electrical problems
Old 10-21-2010, 04:15 PM
Austy's Avatar
Austy Austy is offline
Austy is starting off with a positive reputation.
Cool Electrical problems
OK I have replaced my starter solenoid (which was stuck open), replaced my amp regulator, got my alternator checked out and replaced the brushes on my starter (not that that will fix the problem. And my battery still drains by sitting for 2 days. The only thing I haven't messed with is fuses. Could it be that one of 'em is draining my batt? HELP ME!!! I need my truck working SOON for work. Oh and I also use reconditioned battery's. Should I be using new ones?
Old 10-21-2010, 04:39 PM
Grubbworm's Avatar
Grubbworm Grubbworm is offline
Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.
Have you tried checking for a parasitic battery drain?
Old 10-21-2010, 04:47 PM
Austy's Avatar
A what? Never heard of it.
Old 10-21-2010, 04:51 PM
Austy's Avatar
Oh. OK. I just found out what that is and I made sure all the lights were of doors closed key off everything off and it still drains.
Old 10-21-2010, 04:52 PM
Grubbworm's Avatar
I would do this first;
Depending on what I found out, I would then do this;
Old 10-21-2010, 04:55 PM
Grubbworm's Avatar
More info;
Old 10-21-2010, 05:01 PM
Austy's Avatar
OK I checked my non load voltage and I'm getting 11.4 but it is also half dead so I'll have to charge it more to check load voltage.
Old 10-21-2010, 07:37 PM
CougarJohn CougarJohn is offline
CougarJohn has a good reputation on FTE.CougarJohn has a good reputation on FTE.CougarJohn has a good reputation on FTE.
You have a bucketful of information here. I am seeing 1985 on what is posted but there may be a simpler way.
Turn everything off. Doors closed, all aftermarket electronics disabled. Disconnect the + lead of the battery and look into the truck with an ohmmeter with one lead to ground and one lead to the disconnected lead of the battery. You will read ohms, R.
R=I/12.6.
In other words, 125 ohms will produce a tenth amp of parasitic drain. And so on. You can do the math.
Pop the connection to the voltage regulator and redo the test. The solid state regulator may be causing the problem.
Continue removing fuses until you find the drain.
Your starter is not the problem.
Xstrange will wander into the room soon. He is a very smart guy.
Semper Fi
Old 10-22-2010, 02:07 PM
xstrange xstrange is offline
xstrange is starting off with a positive reputation.
Hi guys;
Sorry I'm late; I've been busy running the business......
All of the above is good....check for a parasitic drain. Think of it like a leaky hose. I normally use a small digital multimeter on the Amps setting. With everything shut off, disconnect the negative cable and put the meter probes on the cable and on the battery post. You shouldn't be seeing any current flow at all. These old trucks don't have no stinkin' computers! If you find some leakage, it's most likely some "aftermarket" wiring, like an audio or alarm system installation. As mentioned above, you track the leak down by pulling one fuse at a time while checking the meter. That'll tell you which branch of the system the leakage is in.
However, first things first......Your comment about using reconditioned batteries raised a warning flag. There are a whole lot of junk batteries out there these days, which will slowly drain down by themselves, just because they feel like it. On one of my cars, I recently went through 3 new Pep Boys batteries (under warranty) before I got one that didn't slowly leak down by itself.
So, check the battery itself first. Pull off the negative cable and measure the voltage across the battery. Let it sit for two days with the cable off and check it again. If the voltage drops by itself with nothing connected, then the battery itself has a small internal electrical leak. A reconditioned battery is even more likely to have that leak than a new one, and it won't necessarily show up on their load test.
Old 10-22-2010, 02:10 PM
Grubbworm's Avatar
Quote:
Originally Posted by xstrange View Post
Hi guys;
Good info.
Old 10-22-2010, 04:59 PM
macattack macattack is offline
macattack is starting off with a positive reputation.
It might be the hi-beam switch, I had a truck that had a similar drain and it drove me crazy till someone suggested I change that switch and it fixed it.
Old 10-22-2010, 08:58 PM
Quote:
Yeah, that's a good possibility too. That's a vulnerable location. If some mud, blood, and beer gets jammed up into the switch, you could get a resistive path to ground from a good-sized hot wire. Not quite a short circuit, but enough to drain the battery.
I should go take a look at the hi-beam switch on my '67 just as a precaution.
Old 10-22-2010, 09:49 PM
raystankewitz's Avatar
raystankewitz raystankewitz is offline
raystankewitz is gaining momentum as a positive member of FTE.
What?!? Reconditioned battery?!?
Okay, that remark about a 'reconditioned battery' threw up a huge red flag!
Before you check anything else, read and note the B+ voltage after you remove both cables from the battery. Now allow a few days for the battery to bleed down and re-check. A good battery will loose no voltage and read the same before and after.
My bet is that 'reconditioned' battery is the culprit. Knowing what it takes to build a battery, I see no proper way to 'recondition' one. I suppose you could drain the battery, wash the cells with water to remove the sulfate sediment, add new acid and charge it again. In all honesty, this is an old battery that's been give the "Snake Oil" treatment.
At any rate, you will probably want a (brand) new battery anyway.
Let us know what you find.
Ray
Old 10-23-2010, 12:35 AM
Austy's Avatar
Ok. I think I got it taken care of. Thanks to Grubbworm. If it comes back I'll let ya'll know.
Old 10-23-2010, 05:57 AM
So, where was the leak?
About the reconditioned batteries:
Most people never notice a battery that has a small leak down. Most "normal" car owners have a single car that they drive at least once a day, and usually several times per day. So they never notice a problem.
And then there are wackos like me. I own two cars and two trucks, all of them 20-44 years old. And I drive about 3000 miles per year total. I have a nice compact life with no daily commute. I try to rotate the use of my vehicles when I need to run errands, but sometimes one may not get its exercise for a week or two. That's why I know about slow leaks in wiring and batteries. One of my cars has a slow leak in some ratty "aftermarket" wiring under the dash and it will be dead in three days. On that one, I automatically disconnect the battery cable every time I park it at the shop. I haven't gotten around to crawling under the dash and fixing it yet.
I've had my '67 F100 for 14 months and haven't had to charge it or jump it yet.
battery keeps draining? |WYG|SS 1978 - 1996 Big Bronco 5 01-08-2012 06:20 PM
7.3 no start when hot blt93932 1999 - 2003 7.3L Power Stroke Diesel 3 08-23-2011 11:00 AM
starting and fuel pump issue 87pomona 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 43 10-12-2010 10:44 PM
Battery Draining - Tips for Diagnosis? jpoesq1 1961 - 1966 F-100 & Larger F-Series Trucks 8 12-02-2008 09:14 AM
Charging System Problems bfuller Ford Inline Six, 200, 250, 4.9L / 300 2 04-24-2004 04:27 PM
Tags
1972, 2007, battery, electrical, f250, failure, find, ford, issues, leak, problems, series, total, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
