Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-21-2010, 06:21 AM
glennemay's Avatar
glennemay glennemay is offline
2004 Ford F-350
glennemay is starting off with a positive reputation.
Aftermarket questions.
OK,
So I bought my 2004 F350 DRW a few months ago. This is an XL with absolutely NO options.
Told myself that I didn't need power windows (I was right)
Told myself that I didn't need power door locks (I was WRONG)
Told myself that the XL sealed beam headlights would be bright enough (Yep Wrong again)
So here are my questions.
I definitely want to install power door locks. Has anyone done it, are there better kits than others, Should I just do the windows at the same time because I will hate myself later?
Headlights. Million dollar question. These POS sealed beams are stupid dim. I have an 05 Expi as well, and they are literally 100 times brighter (Maybe not in lumens, but definitely in visibility. How difficult is the transition to newer lights. Anyone bought them on eBay, which brands, etc.
Thanks in advance.
Glenn
  #2 (permalink)
Old 10-22-2010, 09:26 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to all
The actuators should be pretty typical across the manufactures. AutoLoc and the Hoffman group products are usually well liked. While you're researching it, I would highly suggest thinking about keyless entry, alarm and remote start. You will have to supply power and grounds to the switches and actuators, so you might as well have keyless. The other stuff is fluff, but it's not much more money and it's handy at times.
Headlight upgrade should just be removing the sealed beam bezel and replacing it with new lamps. The trick will be in swapping the h4 style plug for the 9008. In my signature I have some part numbers for to build the 2008 harness, they will be in the 2005 headlight upgrade pdf. I'd be leery of ebay parts, some of the chinese import stuff is junk while some of it is decent. Using Ford parts will be a better bet.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #3 (permalink)
Old 10-25-2010, 12:48 PM
driximus's Avatar
driximus driximus is offline
2002 Ford F-250
driximus is gaining momentum as a positive member of FTE.
Had a Friend in the same situation. His was an F-150, no options he got power windows door locks alarm install and out the door I think he paid 800ish installed. That was through a local guy who does stereos and what not. That was on a 2Dr also though.
__________________
For your entertainment Westley (the Dread Pirate Roberts) Vs Inigo Montoya.
Tags
2010, aftermarket, beam, connect, door, electric, f150, f250, headlight, locks, market, power, sealed, transit, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
