Excessive white smoke after GP and oil change
Changed Glow plugs & relay, oil & filter, air and fuel fiters.
Truck was smoking at all before. Now it smokes white, alot.
Used Beru plus, but i dont tink its the GP's. Just doesnt make sense.
Oil is Shell Rotella T5 synthetic blend 0w40.
I soaked up the oil aroud the GP's before removing them to minimize oil running into the cylinders.
If I accidentally unplugged an injector, would it smoke like this?
Any ideas?
Any ideas?
does it clear up once the motor is warm, or is it like this?
YouTube - Injectors 7.3
YouTube - Start up 7.3 injectors
GPR is from NAPA.
Smoke does not clear up at all. Does is when warm just the same.
And it does not run the same, seems to shake more. It ran real steady before. Its almost as to one hole was doing anything.
Yet if an injector was unplugged it shouldnt fuel that cylinder and not smoke. right?
Problem found and solved
one intake pushrod off the rocker...
<a href="http://s282.photobucket.com/albums/kk253/DirkSteffens/97%20F350/?action=view¤t=IMG00457.jpg" target="_blank"><img src="http://i282.photobucket.com/albums/kk253/DirkSteffens/97%20F350/IMG00457.jpg" border="0" alt="intake pushrod"></a>
koplinhagen
10-01-2015 09:32 AM
No2Oil
15
02-07-2006 09:31 PM
