ZF6 Clutch Issues... - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-20-2010, 07:20 PM
RacerLT250R RacerLT250R is offline
RacerLT250R is starting off with a positive reputation.
i think i broke my clutch fork or throwout bearing. No bad sounding noises have developed yet but truck creeps in gear with clutch peddle fully depressed and is nearly impossible to get in first or reverse to start from a stop. i have to upshift and downshift matching RPM and Speed perfectly. i pulled the slave out of the trans and the plastic cap is still there. a measurement from clutch fork to outside of trans was 2 7/16 inches. should the clutch fork flop around easily up and down and front to back?? Any help would be greatly appreciated thanks.
Old 10-20-2010, 07:31 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
If your fork is bent, it's not bent enough to cause the problems you're seeing.
How does the pedal feel? Is the fluid in thy hydraulics full? Is there a chance your firewall is cracked or weak and the firewall is flexing at the master and not allowing the slave to extend far enough?
Old 10-20-2010, 07:41 PM
the peddle feel changed just before i noticed the problems... it felt like the clutch only partially disengages ... almost like i need more travel but the peddle is already on the floor. i replaced the slave and master 20k miles ago ... i will go check the fliud level. thanks
Old 10-20-2010, 08:38 PM
TinyWonder's Avatar
TinyWonder TinyWonder is offline
TinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to behold
Quote:
Originally Posted by RacerLT250R View Post
i think i broke my clutch fork or throwout bearing....
That sounds a lot like what my clutch/transmission did. It was almost like the tranny fluid had been replaced with peanut butter. Very difficult to shift from one gear to another. Only mine was from first to second... on the same rail in the transmission.
Mine ended up being a cracked syncromesh gear and worn out clutch. But ultimately the cracked syncro was the hard shifting problem.
Search for a post that I started about my transmission troubles. I think I included pictures of the crack and other carnage...
Old 10-20-2010, 08:41 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is offline
Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.
Look at these links. This is a broken fork but you will not have any pedal. The old and new pic was posted by one of the other great members on this site.
Old and New picture by Eddie__S - Photobucket
Broken Fork picture by Eddie__S - Photobucket
Old 10-20-2010, 08:46 PM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
I just change a clutch in a 2000 last Thursday with the same problem. one of the springs in the clutch disc came out and was trapped between the disc and pressure plate and was holding the diaphragm from moving enough to release.
Old 07-05-2012, 10:15 AM
drewinator drewinator is offline
drewinator is starting off with a positive reputation.
Does this picture show a good or bad fork measurement? Is there any official measurement that will tell me if mine is bent? I'm probably going to drop the transmission in mine but i was curious if a measurement like this would give me an indication. Mine shifts fine when it is cold but after a good highway drive or hauling anything it gets warmed up and then is hard to shift into gears. We already replaced the master/slave with a prebled unit and that didn't help.
Old 07-05-2012, 10:46 AM
LSO1123 LSO1123 is offline
LSO1123 is gaining momentum as a positive member of FTE.
Sounds a lot like mine did when my synchros were bad. Except mine did some grinding when shifting. Like yours, mine was always worse once it warmed up.
HELP! Need NP435 clutch fork infinite-foamies 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-19-2016 05:23 PM
Clutch Fork Stymied 1999 - 2003 7.3L Power Stroke Diesel 3 05-21-2016 01:43 AM
looking for clutch fork (number dummy?) Fellenz 1961 - 1966 F-100 & Larger F-Series Trucks 7 02-07-2015 03:49 PM
Clutch/Throw out noise 1997F350CCLB 1994.5 - 1997 7.3L Power Stroke Diesel 4 03-25-2014 01:47 AM
zf5 clutch fork reinstall? peter_x 1987 - 1996 F150 & Larger F-Series Trucks 3 08-14-2012 02:50 PM
Tags
99, bent, clutch, early, f250, fluid, ford, fork, issues, problems, speed, trans, trucks, zf, zf6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
